Battery drain issue
Old Oct 6, 2022 | 03:15 PM
mk-F350's Avatar
mk-F350
4wd Low
Battery drain issue
Afternoon boys, I’ve been working on a new to me 85 F350 6.9idi 4x4 4-speed manual. Had a whole lot of wiring issues I’ve taken care of already. Thought everything was good but now I’m having a battery drain issue. Noticed today that my voltage regulator is warm to the touch,with batteries connected. I had been disconnecting batteries until I got wiring issues fixed. Came out this morning to dead batteries. Alternater has been tested good and regulator is new. Anyone have any ideas on this?
Old Oct 7, 2022 | 01:15 PM
Prototypemech's Avatar
Prototypemech
Just because the regulator is new doesnt mean its good. Was it from Autozone?
Normal key off draw is <100 mA. That keeps the radio and clock happy. You should remove the positive (or negative, it doesnt matter) battery cable off and place a amp-meter between the cable and the battery. This will tell you what your parasitic amp draw is and you can monitor it in real time. While it connected, start pulling fuses and disconnecting suspected items. When the amp meter drops to something more reasonable, you've found your parasitic draw. Happy hunting.
Old Oct 7, 2022 | 03:14 PM
mk-F350's Avatar
mk-F350
4wd Low
thanks for the reply bud, regulator was from Oreillys and I’m pretty sure so far it’s the issue as I swapped it with an older motorcraft I had. issues have went away for now. Plus the new one was warm to the touch while plugged in. Older regulator isn’t doing that. Thanks for the info though, if I have further issues I’ll do as you discribe.
Old Oct 7, 2022 | 05:01 PM
Prototypemech
The alternator B+ lead always has 12volts attached to it. If a diode is bad, it'll draw current through the bad diode and warm up. The alternator tester can usually find this problem, thou.
Old Oct 7, 2022 | 06:23 PM
mk-F350's Avatar
mk-F350
4wd Low
The alternator B= lead always has 12volts attached to it. If a diode is bad, it'll draw current through the bad diode and warm up. The alternator tester can usually find this problem, thou.
Do you mean the alternator will warm up or the does it make the regulator warm up. This was happening while just sitting also.
Old Oct 7, 2022 | 09:15 PM
Prototypemech
The regulator is bolted to the alternator... so technically, the regulator is warming up.
Old Oct 8, 2022 | 10:33 AM
tjc transport's Avatar
tjc transport
i ain't rite
he has an 85 truck. regulator is separate and on the inner fender.
built in regulator is a newer vehicle feature.
Old Oct 10, 2022 | 02:44 PM
mk-F350's Avatar
mk-F350
4wd Low
Since I’ve replaced the regulator everything has been good so far, nothing getting warm.
rodster150
2021+ F150
Dec 30, 2021 10:05 AM
Jontx
2009 - 2014 F150
13
Oct 25, 2021 09:03 AM
Obspowerstroke7.3
Oct 23, 2021 08:08 AM
T diesel
Aug 29, 2020 02:28 PM
Leonandlisa
6.4L Power Stroke Diesel
Jun 16, 2013 02:31 AM
