Need help
Old Oct 6, 2022 | 10:24 AM
Dog8266's Avatar
Dog8266
1st Gear
Need help
F250 new ECM will crank no start no power to fuel pressure pump
please help me out
Old Oct 6, 2022 | 10:34 AM
Tpayne621's Avatar
Tpayne621
Year? I'd check fuel pump relay first. 99-01 it's under radio beside turn signal flasher. 02+ it's built into fuse box inside cab and not replaceable.
Old Oct 6, 2022 | 11:30 AM
Walleye Hunter's Avatar
Walleye Hunter
Do you get WTS light when you first turn the key on?
Old Oct 6, 2022 | 11:54 AM
RacinJasonWV's Avatar
RacinJasonWV
Fuel bowl heater fuse blown? Doesn’t it take out the fuel pump as well?
Old Oct 6, 2022 | 11:56 AM
Tpayne621's Avatar
Tpayne621
I know it kills power to pcm which may very well kill the fuel pump.
Old Oct 6, 2022 | 01:49 PM
udsuth78's Avatar
udsuth78
please help me out
Where did the PCM come from? Are you sure it was flashed properly? Have you checked the inertia switch in the passenger foot well? Try checking for voltage to the PCM relay if voltage is good could try swapping relays to make sure that isn't the problem.
Edit: Were the ignition keys in the house where they belong during PCM work?
Old Oct 6, 2022 | 01:54 PM
pvdiag's Avatar
pvdiag
This is new information. So what happens if the relay fails?
Old Oct 6, 2022 | 03:48 PM
Tpayne621's Avatar
Tpayne621
How I've seen people do it is find the wires that go to it and hook them up to a standard relay. Quick google search should lend some info. Mine is a 99 so I've never dealt with it first hand.
Old Oct 8, 2022 | 11:04 AM
Kwikkordead's Avatar
Kwikkordead
This is what I would do. Why Ford thought it was a good idea to build a relay into the entire body of the fuse panel is beyond me.
Old Oct 8, 2022 | 02:23 PM
bigb56's Avatar
bigb56
Hopefully the OP will come back with more details. One thing that should be checked is vref, if there are any shorted sensors it can take vref down on whatever harness the shorted sensor is part of for instance a shorted EBP sensor can take down vref on that harness and prevent the FP from energizing.
I think a lot of people blame the PCM when vref is down without first disconnecting sensors and checking for shorts.
Silver02sd
May 2, 2020 10:23 PM
drsinisterr69
1997 - 2003 F150
Mar 11, 2016 07:02 PM
fordexplorersport
Feb 11, 2016 06:55 AM
renchr56
Oct 2, 2009 06:26 PM
rlynch131
Aug 26, 2008 07:27 PM
