fuel pump
Old Oct 2, 2009 | 01:08 PM
renchr56's Avatar
renchr56
Thumbs down fuel pump
Ok where to start. Have a guy on road and truck is broke down. I had him check to see if fuel is in fuel bowl. NADDA. I then had him check the fuse for the fuel pump. It is good. I had him check to see if fuel pump is coming on at all.. Nope... I then had him check the fuel cutoff and it is set. I am trying to figure out if someone can tell me where the relay to the fuel pump is located as it is not in the fuse block..
OH by the way it is a 2002 F-550 with 7.3. I know the 2001 had a fuel pump fuse and a relay as well but the 2002 I cannot find the relay. The owners manual does not show one
Old Oct 2, 2009 | 01:15 PM
tdpower's Avatar
tdpower
It would probably be easier to check for power at the fuel pump. Probably only have about 20 seconds to check once the key is turned on. I have not had to mess with the relay but I have heard it is burried in the dash to the left of the radio by the blinker flasher. Don't know if it is the same as the other relays.
Old Oct 2, 2009 | 01:37 PM
renchr56's Avatar
renchr56
Already checked the power to pump and NADDA NONE. That is why I'm asking where the relay is located
Old Oct 2, 2009 | 04:47 PM
Orezona's Avatar
Orezona
Check fuse #22. If blown, unplug the fuel bowl heater and replace the fuse.
Edit: And see post number twelve in this link https://www.ford-trucks.com/forums/7...st-cranks.html for a PDF of fuses and relays.
Old Oct 2, 2009 | 06:26 PM
tdpower's Avatar
tdpower
re
Good point, I should of thought of that earlier.
RickT
Bronco II
Apr 18, 2025 04:10 AM
bristolstud2002
1997 - 2003 F150
Jun 3, 2021 06:21 AM
milehieagle
31
Apr 24, 2021 06:26 AM
2002sport
28
Jan 6, 2015 07:36 AM
CRAZYC123
Aug 26, 2011 10:02 PM
