79 brake light problem
Old Oct 10, 2022 | 04:13 PM
460me's Avatar
460me
Brake light update
Ya maybe a turn signal switch is in order. I can get the brake lights to work on the right filament now, but the 4 way wont flash out back or on the dash with the brake on. They light up just don't flash, let off the brake and they flash.
Old Oct 14, 2022 | 04:53 PM
460me's Avatar
460me
Hell of a battle Everything works as it should.
Old Oct 14, 2022 | 05:21 PM
i-w's Avatar
i-w
What was the fix?
Old Oct 14, 2022 | 05:47 PM
460me's Avatar
460me
Not real sure, but I think it was the two red wires that go to the 4 way flasher only one of the red wires had power. ,The wiring mess at the rear of the truck/one bad socket and cleaned up the grounds. Alot of trial and error.4 ways work, except when the brakes are on, it doesn't flash and stays solid. Maybe that's how it works
Old Oct 14, 2022 | 06:27 PM
1TonBasecamp's Avatar
1TonBasecamp
Yes, that’s how it works.
On newer trucks they have figured out how to bypass all that issue, but on our trucks if you push on the brake the 4-ways stop flashing.
Just as when you put on the brake the selected turn signal still works because it’s all controlled through the turn signal switch.
dbarracuda
Jun 22, 2022 12:30 PM
mikep43019
Feb 17, 2020 07:50 AM
JRT812
Apr 15, 2018 08:53 PM
diablo7308
Electrical Systems/Wiring
Nov 26, 2006 07:36 PM
kc0mdk
Dec 9, 2004 08:58 PM
