2017 A/C wont cool
Old Sep 29, 2022 | 03:24 PM
Scott Clearman's Avatar
Scott Clearman
5th Gear
2017 A/C wont cool
2017 F-150 XL, 5.0L crew cab. My AC wont blow cold air. The ac indicator light on the control panel is on, the compressor turns and the clutch works, actuator door moves. I thought low refrigerant so I got a gauge and can of 123 at the auto store. When i put the gauge on it showed "in the red" which the instructions say means needs service from qualified tech. Is there anything else I can do before heading to the shop?
Old Sep 29, 2022 | 03:31 PM
JKBrad's Avatar
JKBrad
If the system lost it's charge, you need to go to a shop. There is a leak somewhere. If you fill it yourself with some discount auto parts store stuff, you will likely make things worse.
Old Sep 29, 2022 | 07:20 PM
projectSHO89's Avatar
projectSHO89
It hasn't lost its charge, there's something else wrong.
Recommended.
Old Sep 29, 2022 | 11:08 PM
JKBrad's Avatar
JKBrad
Compressor pulley clutch maybe?
Old Oct 2, 2022 | 02:36 PM
PupnDuck's Avatar
PupnDuck
What are the actual gauge numbers? If the system hasn't lost charge it could be a defective compressor.
JaySVX
Aug 25, 2018 11:59 PM
forkhorn
Jul 18, 2015 01:28 PM
marks500
Jun 16, 2014 08:52 AM
Arknessee
2004 - 2008 F150
Apr 8, 2010 06:34 AM
bmore1804
Jul 22, 2006 04:33 AM
