recharging ac
Old Jul 18, 2015 | 08:25 AM
forkhorn's Avatar
forkhorn
recharging ac
Ac is no longer blowing cold air and was thinking about trying a can of ac pro on her. However, i have heard some pretty bad stories about people killing their compressors and overcharging the system. Has anyone haf any luck with this, or is it not worth the risk.
Old Jul 18, 2015 | 08:28 AM
WatsonR's Avatar
WatsonR
Just did mine. Make sure your on the right port (low side) and get the unit with a gauge on it... easy.
Old Jul 18, 2015 | 09:07 AM
tjc transport's Avatar
tjc transport
i ain't rite
you need to do a proper charge. with a real gauge set so you can read both high and low side pressure. those auto parts store AC killer cans has an idiot gauge on them that does nothing.
i have seen the can gauge say there is 35 lbs when a real manifold set says it is actually 60lbs.
and the can gauge does not tell you what the high side is, for all you know you could have a blockage in the system and have a high side up close to 450-500 lbs and not know it until a lien blows.
skip the AC killer can and have it done properly.
Old Jul 18, 2015 | 09:12 AM
dannyboy950's Avatar
dannyboy950
Try to find the one with a trigger or valve that you can control freon flow.
Put it in a little at a time and let the system stabilize a few seconds before chargeing more in. Watch the gauge while chargeing. The gauge will read system pressure before you actually pull the trigger.
At least the ones I have used did. That way you do not overcharge and harm the compressor. If system is real low you may need to jumper the low side switch plug-in to cycle the compressor.
Old Jul 18, 2015 | 09:38 AM
npccpartsman's Avatar
npccpartsman
This....
Best thing I ever did was have it done professionally, even though I had a top of the line Robinaire machine the first 4 or 5 times it was done. It ain't all about the amount of Freon.
Old Jul 18, 2015 | 09:43 AM
Per4mance's Avatar
Per4mance
A/C has to be vacuumed down to function properly.Also you have to change the reciever /dryer and orifice tube. A scale for freon is a BIG help too
Old Jul 18, 2015 | 12:32 PM
tjc transport
i ain't rite
on average i get 3-4 per year that come in with "i put a can of ac pro( or whatever killer can) in and it still don't work" only to put the manifolt set on and see high side pressures over 400 lbs. then they bitch about it costing $200 to $250 to repair AFTER they spent $45 for the AC killer in a can.
Old Jul 18, 2015 | 01:28 PM
r2millers's Avatar
r2millers
Have you checked to ensure the a/c clutch is operating properly, allowing the compressor to turn?
It might be a clutch clearance issue, lots of threads here, or a low pressure sensor switch that won't allow it to operate?
I'd start there first.
nmarcoe
1997 - 2003 F150
Aug 29, 2013 05:20 PM
89ford73
21
May 14, 2011 10:08 PM
bcjim
Oct 27, 2008 07:32 PM
bmore1804
Jul 22, 2006 04:33 AM
andy_nominous
Aug 15, 2005 07:27 PM
