Sponsored by: Real Truck
99 F250 Powered Locks
Old Sep 22, 2022 | 06:26 AM
Dexxter115's Avatar
Dexxter115
8th Gear
Hello. My new to me 99 F250 has been a blast to own. The truck has powered locks, and when I try to use the fob or the buttons on the doors to unlock it, I can hear the motor working, and see the locks move a bit, but it will not cycle between locked and unlocked, or vice versa. It does this on all 4 doors of the vehicle. The key turns the lock fine, and moving the black lock tabs by hand I dont feel any resistance difference than on my fathers 99 F250, which the power locks work on. Not sure if its important or not, but if I press the button/door button rapidly, I get 3-5 'tries' before the motor stops trying to cycle the lock, and it gets weaker every time. Letting it sit for ~7 seconds, and it will try again another 3-5 times. Any thoughts on what I could check or try to make these work without putting the key in the door or moving them by hand? Thanks
Old Sep 22, 2022 | 07:54 AM
Djosbun's Avatar
Djosbun
See what kind of voltage reading you’re getting at the power lock connector. If the actuator is good then you’re having voltage drop.
— Dave
Old Sep 22, 2022 | 09:14 AM
Dexxter115's Avatar
Dexxter115
8th Gear
Dave, by the power lock connector do you mean the connector plug? I apologize, I am not familiar with electrical systems so it is a bit of a foreign concept to me. Thanks
Old Sep 22, 2022 | 09:18 AM
runthatjunk's Avatar
runthatjunk
Seems like there is a contact in the lock motors that gets weak. It is a thermal switch basically. If the button is held down it gets hot and breaks contact to prevent overheating. These will get weak if they break contact a lot. Google it, seems like it was a relatively easy fix.
Old Sep 22, 2022 | 02:28 PM
user 195474726373's Avatar
user 195474726373
I have the same problem with my new to me '99 F250 SD. I hear the actuators wear out. I'm going to get a couple before I tear the door apart. On the plus side my dogs can't lock me out any more!
chief1232
May 9, 2022 09:16 AM
mattpowerstroker
1997 - 2003 F150
Feb 11, 2010 12:51 PM
78'fordtruckguy
Electrical Systems/Wiring
Jul 9, 2007 12:20 AM
hons
Apr 10, 2007 03:31 PM
