High boost pressure
Old Sep 17, 2022 | 09:20 AM
Gregg1968's Avatar
Gregg1968
5th Gear
High boost pressure
The other night I was getting on the freeway. I gave a little throttle the truck shifted really hard. After that I noticed cruise body pressure to be roughly 17-18 psi and climbing a little hill would go to max boost on stock turbo with really no power gain. Truck seams to shift some what ok. Just high boost pressure. Completely stick engine with 60hp tune. 330,000. A little help would be appreciated.
Old Sep 17, 2022 | 09:35 AM
blicharski1989's Avatar
blicharski1989
Any codes? Could be the turbo VGT sticking or your EBP sensor needs to be cleaned out.
Old Sep 17, 2022 | 12:31 PM
Gregg1968's Avatar
Gregg1968
5th Gear
No codes not read them yet. Turbo is a year old. I will check the ebp. Thank you
Old Sep 18, 2022 | 02:25 PM
Gregg1968's Avatar
Gregg1968
5th Gear
I pulled codes. No codes present for EBP or MAP sensor. Checked out for map sensor. It was clogged. Cleaned it out and ready drove still sad concern. I guess I pull turbo next and check the vanes. Maybe
Gregg1968's Avatar
Gregg1968
5th Gear
Old Sep 18, 2022 | 02:33 PM
bismic's Avatar
bismic
Curious - what are you using to check for codes?
Old Sep 18, 2022 | 03:44 PM
Gregg1968's Avatar
Gregg1968
5th Gear
Just a little code reader from Matco. Nothing fancy.
I have to get with a buddy of mine to get anything better
Old Sep 19, 2022 | 01:34 PM
FiveOJester's Avatar
FiveOJester
Did you check the EBP tube for clogging?
On the MAP sensor make sure to check the hose & the brass nipple that threads into the intake manifold.
Oilfield Trash
17
Mar 2, 2016 12:41 PM
2006White60
May 4, 2014 11:35 PM
GDAWG 2012XLT
6.7L Power Stroke Diesel
Feb 3, 2012 11:25 PM
AndeyHall
Jul 22, 2010 11:35 AM
wmiller
17
Aug 10, 2007 04:16 PM
