Distributor Replacement
Old Sep 16, 2022 | 12:22 PM
tsam's Avatar
tsam
1st Gear
Hello, new to the forum. I am going to replace my distributor with a H.E.I. and was wondering if the electronic box on the fender only works the distributor or is it needed for something else? Can it be removed or is it needed? Thanks
Old Sep 16, 2022 | 01:41 PM
beartracks's Avatar
beartracks
I would recommend an MSD stand alone dizzy. All you need is an appromriate coil and a hot wire.
Old Sep 20, 2022 | 08:10 PM
Ralston76's Avatar
Ralston76
Can we get this answered
I Think it can be removed. If you’re changing to a different system. But I’m not sure so I’m just commenting to put this back up to the top of the pack so hopefully somebody a little wiser can answer your question. But if you’re going to HEI I don’t think you need it.
Old Sep 21, 2022 | 06:41 AM
mudbogger2's Avatar
mudbogger2
It can be removed. HEI distributors have the ignition modules built into them. There will be no other use for the module once you install the HEI distributor.
Old Sep 21, 2022 | 06:50 AM
FuzzFace2's Avatar
FuzzFace2
If you have DSII distributor and box why replace it with that big thing you may not be able to adjust timing as the vacuum can hits things?
Dave ----
Old Sep 21, 2022 | 08:17 AM
Old Guy F-250's Avatar
Old Guy F-250
I replaced mine in my 300 as the module was melting down. So now it starts up really fast and runs great, No need to carry an extra module...
HOWEVER, as Dave mentioned, it is a real PITA to set timing, I would assume it is the same on the V8.
Would I do it again,, not sure.
Alex
Old Sep 21, 2022 | 08:48 AM
mudbogger2's Avatar
mudbogger2
It is not any harder on the 351M to set timing even with a/c. I have plenty of movement when turning the distributor to set timing. I am very happy with mine but the only drawback was making custom spark plug wires to fit the ford/chebby mash up. I would do it if I were to build another one.
Old Sep 21, 2022 | 09:36 AM
Evan76's Avatar
Evan76
Was super easy on my 300. Seemed to also work when it was a 360. I did do something with a coolant line to clear better.
Yes got rid if everything but one power wire
Old Sep 21, 2022 | 09:47 AM
tbear853's Avatar
tbear853
My DS has been flawless from day 1 except when the module lost it's potting back a few short years ago, cheap, easy roadside swap. Spares are cheap. I've had more problems with GM HEI when I had them. I never had problems with points though.
But NO, the box on the fender apron is not used with HEI.
Old Sep 21, 2022 | 01:45 PM
Ralston76's Avatar
Ralston76
You Guys are awesome
Thanks guys for answering his question I knew you guys that had done the swaps before could get him the answer he needed. I didn’t think you needed it but I wasn’t sure if it ran something else also.
rswhitmore
Mar 16, 2022 09:16 AM
chris989
Sep 19, 2021 07:52 PM
NS70250
15
Sep 11, 2015 07:43 PM
josher66666
Jan 23, 2009 08:50 PM
gatorbait
May 5, 2004 08:58 AM
