VSS question
Old Sep 16, 2022 | 11:48 AM
THE FISH BAIT's Avatar
THE FISH BAIT
VSS question
My 99 4x4 with rebuilt trans just started throwing some strange codes, but the most common code is P0500. The speedometer quit working and OD light started flashing, along with hard shifts. After some reading here it looks like a bad VSS can cause all kinds of strange symptoms so I’m going to try that first. I can’t find an OEM Motorcraft replacement, do y’all recommend any particular brand of aftermarket.
Old Sep 16, 2022 | 11:55 AM
THE FISH BAIT
IAH and EBPV are deleted.
Old Sep 16, 2022 | 12:06 PM
kbeefy's Avatar
kbeefy
All those sound like a bad sensor. Sometimes removing it and cleaning it help, not always though. It's 23 years old anyways.
F81Z7M101BA seems to be available from most sources.
It's just a speed sensor, and the ford ones are pretty pricey. I'd be fine with a Delphi, or the higher end store brand with a decent warranty.
They're likely all from the same place anymore anyways.
Old Sep 16, 2022 | 01:10 PM
THE FISH BAIT
OK, the part number I was given from Ford was F85Z9E731AB. He said it was no longer made and didn't have a replacement number, but every parts house around here has aftermarket for it. I figured I would give the aftermarket a shot, like you said it's just a speed sensor and pretty easy to change.
Old Sep 16, 2022 | 02:34 PM
kbeefy's Avatar
kbeefy
Eh, the one I listed might be a transmission output sensor....
Old Sep 17, 2022 | 07:11 AM
THE FISH BAIT
The dude at ford said your number was the trans sensor. I wound up getting one from advanced auto. Put it in last night and so far so good. Thanks for the response.
Old Sep 17, 2022 | 10:24 AM
BWST's Avatar
BWST
Got Data?
Good deal. I see Riffraff is out of that sensor again, darn it. Glad you did not have a wiring issue to the sensor. A new VSS fixed my P0500 as well.
finn12
Jan 24, 2017 12:39 PM
Elbovis
Aug 1, 2012 01:54 PM
tygerrrr
Jun 15, 2011 03:24 PM
D_Dillen
Feb 20, 2011 12:37 PM
pwstroker69
20
Nov 17, 2008 11:56 AM
