Modular V10 (6.8l)
Hole to nowhere?
Old Sep 8, 2022 | 08:30 PM
boltman704's Avatar
boltman704
2nd Gear
Hole to nowhere?
Good Evening:
I have a 2008 Ford E-450 (my first Ford) motor home. Last weekend I started getting an intermittent miss. Got home and hooked up the scanner and got a P0304. Ok probably coil pack, plug. injector, or vacuum leak. When I pulled the dog house off inside the cab (first time I have had it off) the first thing I see on the passenger side is a partially open hole on the back of the cylinder head. I am thinking this does not look right. I go to the Ford parts house and he shows me a new plenum. It looks like mine (nothing broken or missing on mine). He gets a plenum gasket out (same gasket for either side) and it is fitted around the open hole just like mine is. I have enclosed a picture or two showing this and hopefully some of you guys can shed some light on this. I really appreciate any feedback!!
The Boltman
Old Sep 9, 2022 | 04:01 AM
JWA's Avatar
JWA
This has been discussed here before but I'll be switched if I can remember what it is supposed to do. IIRC the consensus or knowledge base said it was of no concern.
Sorry I can't be of further help.
Old Sep 9, 2022 | 06:07 AM
projectSHO89's Avatar
projectSHO89
Here's one: https://www.ford-trucks.com/forums/1...-aft-head.html
Old Sep 10, 2022 | 05:41 AM
JWA's Avatar
JWA
Originally Posted by projectSHO89
I knew there was something out there somewhere!
Old Sep 10, 2022 | 05:59 AM
projectSHO89
Yeah, I just searched this sub-forum for "hole"!
Old Sep 10, 2022 | 03:32 PM
boltman704's Avatar
boltman704
2nd Gear
Thanks for the help!! Sometimes I just don't understand what the engineers are thinking. I am sure it has to do with cost savings though.
Old Sep 10, 2022 | 09:54 PM
projectSHO89
If you read the other thread, you'd know what they were thinking.
Old Sep 11, 2022 | 01:59 AM
CathedralCub's Avatar
CathedralCub
FTE Community Team
Yeah it's no cause for concern. Here's the thread I started on this same question when I was newer around here: https://www.ford-trucks.com/forums/1...open-port.html
gootz4u
1997 - 2003 F150
Aug 9, 2022 07:21 AM
Stapler123
Aug 5, 2022 06:40 AM
Sean Smith
May 29, 2019 06:30 AM
abe
15
May 31, 2017 07:38 PM
bimmertrek
Modular V10 (6.8l)
Sep 23, 2010 12:45 AM
