SD injectors in an OBS
Old 09-07-2022, 03:26 PM
7.3dugas's Avatar
7.3dugas
7.3dugas is offline
4wd High
Hey guys I wanting to know what y’all think, I’ve got a guy that might be getting me AD injectors and a turbo from a 02 f250. Do think that will be a good upgrade or should I wait and get a new KC turbo and 205cc injectors.
Thanks
Old 09-07-2022, 04:52 PM
Bitterroot Diesel's Avatar
Bitterroot Diesel
Bitterroot Diesel is offline
Former Vendor
Just depends on your goals.
Old 09-07-2022, 05:25 PM
7.3dugas's Avatar
7.3dugas
7.3dugas is offline
4wd High
Well eventually I want to pull the engine and do a complete performance rebuild. But I’m wanting to make more power with out doing to much to the point of blowing the engine or spending a whole lot.
Old 09-07-2022, 07:38 PM
timlange's Avatar
timlange
timlange is offline
I wouldn’t waste time on super duty turbo. I also wouldn’t put super duty injectors in. They get worst fuel economy and require tunning to run. I have a truck with 160/30s and a modded stock obs turbo, feels pretty good. I’d wait till you got the coin, but I just try to avoid doing things twice
Old 09-07-2022, 07:47 PM
7.3dugas's Avatar
7.3dugas
7.3dugas is offline
4wd High
Ok that’s fair, that’s what a was leaning towards but I wanted a second opinion. Thank you!
what mods did you do to your turbo?
Old 09-07-2022, 08:20 PM
Bitterroot Diesel
Former Vendor
AD/30's would be recommended if you wanted a quiet injector that has great cold manors. How you drive the truck will have a larger effect on mpg than injector choice. Used injectors usually leave a lot to be desired.
Old 09-08-2022, 06:57 AM
timlange's Avatar
timlange
timlange is offline
Deleted pedestal, ebp deleted, 360 bearing and a down pipe which is probably the most important, also upipes gaskets if yours are leaking which probably are if they never been changed. Honestly pretty cheap parts that will let that turbo breathe and sing a little better.
Old 09-08-2022, 12:13 PM
knottyrope's Avatar
knottyrope
knottyrope is offline
we have single shots and 15 degree HPOP
SD uses double shots and 17 degree HPOP (more volume)
can get tunes but then its trying to do something that the 15 degree HPOP might not be able to feed on full throttle
billgrant
07-16-2019 12:12 PM
bduemig
07-24-2012 08:32 PM
alteredspeed
02-07-2010 10:37 PM
brickie
09-03-2007 03:34 PM
96powerstroke
03-29-2006 06:13 PM
Quick Reply: SD injectors in an OBS
