SD injectors in an OBS
Hey guys I wanting to know what y’all think, I’ve got a guy that might be getting me AD injectors and a turbo from a 02 f250. Do think that will be a good upgrade or should I wait and get a new KC turbo and 205cc injectors.
Thanks |
Just depends on your goals.
Well eventually I want to pull the engine and do a complete performance rebuild. But I’m wanting to make more power with out doing to much to the point of blowing the engine or spending a whole lot.
I wouldn’t waste time on super duty turbo. I also wouldn’t put super duty injectors in. They get worst fuel economy and require tunning to run. I have a truck with 160/30s and a modded stock obs turbo, feels pretty good. I’d wait till you got the coin, but I just try to avoid doing things twice
Ok that’s fair, that’s what a was leaning towards but I wanted a second opinion. Thank you!
what mods did you do to your turbo? |
AD/30's would be recommended if you wanted a quiet injector that has great cold manors. How you drive the truck will have a larger effect on mpg than injector choice. Used injectors usually leave a lot to be desired.
Originally Posted by 7.3dugas
(Post 20548361)
we have single shots and 15 degree HPOP
SD uses double shots and 17 degree HPOP (more volume) can get tunes but then its trying to do something that the 15 degree HPOP might not be able to feed on full throttle |
