Speed sensor questions
Old Sep 4, 2022 | 03:20 PM
86bullnose4x4's Avatar
86bullnose4x4
I'm not a 7.3psd owner. I'm wanting to know does the ZF5 have a speed sensor that connects to the speedometer or is it located somewhere else?
Old Sep 5, 2022 | 06:11 AM
tjc transport's Avatar
tjc transport
i ain't rite
depends on what year. 88 to 91 has a speed sensor on the speedometer cable to work the cruise control. 92 went to digital speedometer and newer uses a sensor in the rear axle to run the speedometer instead of a cable..
Old Sep 5, 2022 | 08:14 AM
86bullnose4x4
So if I wanted to swap a power stroke into my 86 will the older transmission work with the newer engine?
Main reason I'm asking is because I want to do the swap but I want to try to keep the gauge cluster original. If it's doable
Old Sep 5, 2022 | 09:42 AM
tjc transport
i ain't rite
it can still be done, you would just have to use a 88 to 91 ZF-5 with speedometer cable port for a two wheel drive, or use your 86 transfer case on the powerstroke trans if you have 4 wheel drive. .
Old Sep 5, 2022 | 12:07 PM
86bullnose4x4
Okay and I'm guessing I'd have to already have a standard transmission in order to use the 86 transfer case? It's currently an automatic 4x4.
Old Sep 5, 2022 | 12:19 PM
tjc transport
i ain't rite
a ford full size truck transfer case don't care what trans it is bolted to.
so your current transfer case will bolt to the diesel 4 wheel drive ZF5 speed .
Old Sep 5, 2022 | 01:09 PM
86bullnose4x4
Okay I appreciate the help
onejerry
Jul 6, 2011 08:11 PM
nanufree
Dec 19, 2005 12:33 PM
Big_worm
Nov 21, 2005 04:27 PM
lwpman
Apr 28, 2004 08:41 PM
Ken
1997 - 2003 F150
Jan 7, 2000 04:26 PM
