Sponsored by: Real Truck
Speed Sensor
Old Nov 18, 2005 | 02:49 PM
Big_worm's Avatar
Big_worm
Speed Sensor
The speed sensor in my truck needs replacing. Does anyone know how I can do this myself without having someone else working on my truck? It is a F-350 7.3 liter power stroke diesel.
Old Nov 18, 2005 | 05:09 PM
wlihntr's Avatar
wlihntr
its a piece of cake, it is located on the top of the rear diff, is held in buy 1 bolt (10mm i believe) the part is $25-$30. it is also called a VSS (vehicle speed sensor) should take you 5-10 , minutes
Old Nov 18, 2005 | 05:23 PM
captchas's Avatar
captchas
Guest
don't be scared it's a peice of cake as said above 1 bolt .
good luck
Old Nov 20, 2005 | 08:35 AM
dirttoo's Avatar
dirttoo
What does the speed sensor do? Would replacing it correct my speedometer if it reads about 8-10 mph fast at 55 mph? I have taller tires and it still reads fast. Any other suggestions? Thanks
Old Nov 20, 2005 | 09:39 AM
FortyFords's Avatar
FortyFords
Speed sensor is used for abs system,auto trans shifting,cruise control and speedo and 4x4 for shifting .Its called VSS (vehicle speed sensor)
You need to have the speedo calibrated at the dealer or some tuners have the ability to do it
Rich
Old Nov 21, 2005 | 02:27 PM
Big_worm's Avatar
Big_worm
Thanks
I appreciate all the feedback. I am going to try and put it on today.
Old Nov 21, 2005 | 04:27 PM
ColtM4's Avatar
ColtM4
it may only need cleaning if your speedo is doing wierd things. You may want to try and just remove it and wipe it off replace the old one to see if that fixes the problem. It attracts metal particles which affects the ability to sense a signal from the tone wheel.
