Sponsored by: Real Truck
4r100 trouble
Old Sep 3, 2022 | 02:20 AM
valliant75's Avatar
valliant75
4wd High
4r100 trouble
I just rebuild my 4r100 alto powerpacks and transgo tugger shift kit.
Did ewerything after the book and worked fine,oil is clean etc.
But some how its sudenly got som issues after pulling tranny back again too change flexplate.
Slow too engage reverse,must give a litle throhle,then strong in reverse no slipage,but makes a whining hydraulic noise(like safety valve blow sound)
when first in R it uses some time too relase again.can also hawe same symptoms when auto downshift from 3rd too 2cond.
These isues come and goes,sometimes works perfect sometimes like my descreption.
For me it apears like valve sticking ore electrical,but im no expert on 4r100 trans ,but im 100% the internal tranny is put together right.senter suports used loctite and moment etc,
from a dead start and full acceleration al gears hold strong.
Im living countryside in Norway so werry few specialist workshops in these country and theyr far away(4.500.000 citizen in Norway)
Im thankfully for tips too check out.
Best regards Kjetil Sollid
Old Sep 4, 2022 | 03:53 AM
351Cleveland C4's Avatar
351Cleveland C4
Check the plug on the passenger side. Causes all sorts of issues if it's dirty or loose.
Old Sep 4, 2022 | 04:06 AM
valliant75's Avatar
valliant75
4wd High
i did and it works percectly i reverse with these disengaged
Old Sep 4, 2022 | 08:26 AM
AuroraGirl's Avatar
AuroraGirl
I dont think he and you have the same thing in mind
Old Sep 4, 2022 | 09:27 AM
Mark Kovalsky's Avatar
Mark Kovalsky
Frmr Ford Trans Engr
rebuildt 4r100 troubles
slow too engage revers,must give a litle throtle.strong in r when first engage sometimes also slow too disengage from reverse.
These symptoms are gone when pulls the conector too nthe solenoid pack.
I think something is wrong inside the reverse clutch.
When you unplug the connector the pressure control solenoid goes to maximum pressure. All that additional pressure is why the problem doesn't happen with the connector removed. It isn't an electrical problem.
Old Sep 4, 2022 | 09:40 AM
valliant75's Avatar
valliant75
4wd High
It happening after pulled tranny 30 cm back too changw flexplate.if leak in clutch pack it should slip?its no slip.it also works fine again sometimes,after its hot,like 150fahrenheit.
something mechanical wrong in a clutch dont come and go,what u think of solenoids?was love ohm on them
Old Sep 4, 2022 | 10:48 AM
valliant75's Avatar
valliant75
4wd High
i read the codes,its saying solenoid a and b.
Old Sep 4, 2022 | 11:54 AM
Mark Kovalsky
What codes did you get?
The shift solenoids are not used to engage or release reverse.
Old Sep 4, 2022 | 01:48 PM
valliant75's Avatar
valliant75
4wd High
i did solenoids a and b,these ewening i had of valvebody and air checked clutches,seems too be ok with out leaks.
93f1505.0L
Jul 3, 2008 02:07 PM
78250crewcab4x4
Mar 25, 2007 12:19 AM
mongo75
Jan 11, 2007 03:00 AM
dmc919
Aug 29, 2004 06:38 PM
bigslurrp
Jun 4, 2004 05:11 PM
