c4 trans nees help
Old Aug 28, 2004 | 05:06 PM
dmc919's Avatar
dmc919
c4 trans nees help
I just got the tranny rebuilt put it in and it shifted crazy so i took it back and the tranny guy said whoever had it before me improperly installed a shift kit, so he put in a new valve body, then put trans back in and it would start in 2nd gear and shift early into 3rd, took it back the tranny guy and he said the governer was sticking and to drive it around untill it fixed itself. Now a day later the tranny acted like it was in neutral so i put it in park and checked fluid. It was about 3inch higher than it was yesterday, like if i were to check it if the engine wasn't running. The tranny will occasionaly work for about 20 seconds and then slip into neutral in all gears 1-2-D-R, if i wait about a minute it'll slip back into drive and last for about 20 seconds. what the heck it going on, do i just have bad luck or does my tranny guy know **** about transmissions.
Old Aug 29, 2004 | 06:35 PM
dmc919's Avatar
dmc919
Anyone got an idea?
Old Aug 29, 2004 | 06:38 PM
68torino's Avatar
68torino
I would take it back. The guy did not do you right. He may have not installed the valve body right, left out some check *****, may not even have rebuilt it at all.
