Hard to say without more information. I've seen new cam bearings spun because the bearings weren't worked for clearance. it could have several thousand miles on it before it got to this point even if the bearing seized early on.
I always scrape the bearings where needed then with oil on the bearings I run the cam with a drill until I can move it easy with 2 fingers on the bolt.
