Trans Fluid Amount
Old Aug 31, 2022 | 07:01 PM
Motohead911's Avatar
Motohead911
Trans Fluid Amount
Does anyone know how much fluid I need for doing and trans filter change. I do have the 6.4 filter upgrade already. I was planning on 2 5 quart jugs of LV.
Old Aug 31, 2022 | 08:37 PM
TooManyToys.'s Avatar
TooManyToys.
I have in my notes to purchase 10 qts, and I believe on my dipstick I have a note for 9 qts.
Old Aug 31, 2022 | 09:59 PM
Theboneskes's Avatar
Theboneskes
I used just shy of two 5 quart jugs of Motorcraft LV. I changed the temp sensor which takes a small amount more. Get 2 jugs and you will be good.
Old Sep 1, 2022 | 11:04 AM
diesel_dan's Avatar
diesel_dan
+1 for Jack - Mine took 9 on refill with a new filter in a 6.4 pan/filter set-up...
Old Sep 1, 2022 | 11:25 AM
Motohead911
Thanks guys, I have 2 5quart jugs on the way from Rockauto. Now I need your opinion, on the TP filter in the front. Replace or not? it has 30k on it. The pan filter will be replaced.
Old Sep 1, 2022 | 11:35 AM
TooManyToys.
I vote for replacing it. While it's not getting the amount of debris as before, there's no way to qualify that. And since it is so cheap if you get the NTZ version, its hard even for me to let go.
The guy on the other shoulder says keep it in for two changes.
Old Sep 1, 2022 | 11:44 AM
diesel_dan's Avatar
diesel_dan
+1 on Jack's comment - you could also just leave it in there forever - just don't run that front canister empty...
Old Sep 1, 2022 | 10:55 PM
Yahiko's Avatar
Yahiko
Keep the filter in it, or remove the assembly and plumb around it.
Running it without the filter messes with the bypass port in the housing.
You want the oil to take the correct path.
Old Sep 2, 2022 | 08:20 AM
Theboneskes
Agree, just replace it while its apart. Cant hurt... the filter costs nothing compared to the fluid. I found a better deal on Amazon for Motorcraft LV than Rock Auto when bought it about a month ago...
Ford_Man03
15
Jun 3, 2021 06:44 AM
Copedawg
Feb 11, 2011 05:40 PM
TexasTornado66
May 7, 2010 01:40 AM
linkford
May 30, 2007 06:50 PM
bill99psd
15
Feb 23, 2007 09:35 AM
