Sponsored by: Real Truck
Squeaky steering
Old Aug 27, 2022 | 03:07 AM
Tony2times's Avatar
Tony2times
2nd Gear
Squeaky steering
04’f250 5.4 2WD 200k mi….
Squeaks with any movement of the steering wheel. Power steering fluid level good. Bushings look good. Is there something I can grease? What is this squeak?
Old Aug 28, 2022 | 10:06 AM
udsuth78's Avatar
udsuth78
Likely the ball joints.
Old Aug 28, 2022 | 04:30 PM
bajaphile's Avatar
bajaphile
Where is the squeak coming from... Steering wheel? Wheel/Tire area? Engine?
Old Aug 28, 2022 | 04:59 PM
Djosbun's Avatar
Djosbun
Lots of things can cause a squeak. If you want to locate the cause, get under the truck and start inspecting all rubber components in the front end PLUS the body mount bushings.
— Dave
Old Aug 28, 2022 | 05:21 PM
udsuth78's Avatar
udsuth78
"Squeaks with any movement of the steering wheel." This screams ball joints. Unless this squeak is actually a whine from the power steering pump, which would be air trapped in the system or failing pump since OP says it's full. Suspension wouldn't likely squeak from every input of steering, tie rods don't typically squeak because they don't support any load. Ball joints support the entire weight of the front half of the vehicle and pivot during any steering input. Just sayin.
Old Sep 3, 2022 | 03:38 PM
user 195474726373's Avatar
user 195474726373
Do you have grease fittings? I think I'd jack the front off the ground and see what happens. If it stops then I'd go with ball joints.
Nick1987
Missouri Chapter
May 8, 2018 11:30 PM
PSUJTF76
2004 - 2008 F150
Aug 14, 2009 01:07 PM
Mustangfreak
May 13, 2009 08:01 AM
afonda
Feb 11, 2009 05:33 PM
