Sponsored by: Auxito
Neglected truck
Old Aug 26, 2022 | 02:04 PM
Tclint's Avatar
Tclint
2nd Gear
Neglected truck
1997 Ford F150 with 4.6L has sat for about 3 years. I put some new gas and a new battery in it and tried starting it without any expectations and it won't start.
I figure the injectors are plugged up from bad gas.
Am I going to have other problems?
I know it ran good, without any problems before the owner parked it.
I'm an old school mechanic and never worked on fuel injection before.
I miss carbs right now.
Old Aug 26, 2022 | 03:15 PM
Jon Freeman's Avatar
Jon Freeman
Check to see if there is any fuel pressure.
Old Aug 27, 2022 | 03:25 PM
Tclint's Avatar
Tclint
2nd Gear
I determined I wasn't getting any fuel to the fuel rails. I checked the fuel filter and it seems to be ok.
With the fuel line off the fuel filter, should I see fuel running out when I turn on the ignition?
Old Aug 27, 2022 | 05:01 PM
manicmechanic007's Avatar
manicmechanic007
Damn straight
With the filter removed or some other break in the fuel pressure line
You should see a bunch of fuel squirt out each time you cycle the key
Old Aug 29, 2022 | 12:56 PM
'65Ford's Avatar
'65Ford
Should be able to hear the pump run when turning the ignition key to "Run"...(not "Start"). If you or a buddy with ear near the fuel tank can't hear it then that's where the trouble shooting needs to start.
Old Aug 30, 2022 | 02:14 PM
WWR's Avatar
WWR
So much this. But don't jump straight to fuel pump replacement as so many do. First check relays and fuses. AFTER all that then lower tank enough to get at electrical connector for pump and see if power (and ground) is getting that far.
Can't blame the pump for not running if it's not being told to run.
I don't recall if the bubble bodies have a dedicated fp relay or is it integrated into something bigger? If a standalone relay, bypass relays are great for troubleshooting but a jumper wire can achieve the same result with slightly less elegance.
Old Aug 30, 2022 | 05:56 PM
'65Ford's Avatar
'65Ford
Here's the dictionary definition of "trouble shooting"...
- to trace and correct faults in a mechanical or electronic system.
No one said to jump straight to replacing the fuel pump. Listening to fuel pump lets you know if you need to diagnose (i.e trouble shoot) the fuel pump system or look for a clogged line.
Old Sep 3, 2022 | 09:31 AM
Airborne 82nd's Avatar
Airborne 82nd
The fuse for the fuel pump relay is # 19 (20a) under the dash by drivers left foot. The relay is under the hood driver side in the power distribution box. You also have a inertia fuel pump shut off behind front passenger kick panel. Fuel pump and pump module are at the tank.
Hope this helps.
Airborne 82.
Old Sep 3, 2022 | 03:20 PM
explorerdriver's Avatar
explorerdriver
Sometimes if the fuel pump has an open, it will set a code in the computer. Scan for codes. It does on the crown vics (same powertrain as the truck).
Old Sep 4, 2022 | 05:20 AM
manicmechanic007
The electrical systems are so robust and fail safe
I jump right on replacing the fuel pump, most of the time, if no pressure is present
The ones that have a fuel pump driver module, I inspect that first
Tclint has no FDM
I would have replaced the fuel pump already
If you are in doubt, just check the feed voltage to the pump, after you get the tank down far enough to access the wiring connector
Old Sep 4, 2022 | 08:58 PM
Airborne 82nd
Tclint has no FDM
I have the same truck along with the Ford factory service manual the big one that the dealer used. It shows one on this truck on the electrical print and on the component chart. Are you sure it does not have one?
Old Sep 6, 2022 | 11:37 AM
rbtom's Avatar
rbtom
Check if there are any codes in the computer.
is the theft light flashing in the dash ?
Chris Gathof
Oct 23, 2017 06:53 PM
tigerfan79
Jan 21, 2014 01:46 PM
exporangerman
Mar 18, 2009 04:57 PM
bullit340
Feb 6, 2008 07:29 PM
wdj
Feb 20, 2003 07:49 PM
