Wiring harness party
Old Aug 26, 2022 | 08:54 AM
GASPIG88's Avatar
GASPIG88
I have a 1991 Bronco with a 302/E4OD in it. I am swapping in a 1991 351W i found with low miles. (going to re seal everything and check all tolerances anyways).
My problem (i think) is that my donor vehicle is a 2wd standard shift. (1991 F250)...
Will my existing wiring harness work with a correct ECM from rock auto? 351w/E4OD ECM...
Old trail recovery prep pic just for fun, was headed out in my 86 to recue a friend with a mangled control arm on his 93.
Old Aug 26, 2022 | 10:29 AM
rla2005's Avatar
rla2005
No need to swap any wiring, use what you already have. Some say to try using the 5L computer to run the 5.8L engine. If it appears to run lean then swap in a comparable year 5.8L computer. If it were me I would go straight to the correct year/engine/trans computer.
Old Aug 26, 2022 | 12:14 PM
GASPIG88's Avatar
GASPIG88
Thanks!
This will hold over until i can do something more. (Sniper EFI and Cam/Heads/Intake) just not in the budget right now. Life got expensive lately.
Jerry_85ford
Jul 14, 2022 01:28 PM
JClark785
Nov 13, 2016 07:52 PM
Josrobinson
Jun 22, 2014 02:09 PM
Micheal86
Jan 20, 2011 02:59 PM
radramrod2
Jan 26, 2005 10:33 AM
