MUSTY SMELL W/ AIR COND. USE
Old Aug 15, 1999 | 08:06 PM
Tim Pog
Guest
Posts: n/a
What causes the musty smell when i use my air cond. How can i fix the problem? Thanks, Tim
Old Aug 16, 1999 | 09:00 AM
ray's Avatar
ray
You do not say what vehicle you have but Ford has issued some TSBs on that subject. ray
Old Aug 16, 1999 | 09:28 AM
Kevin's Avatar
Kevin
Easiest thing to check is the drain on the evaporator box inside the cab. It's where the moisture collects after the air is cooled and the moisture is pulled out of the air. It should be draining outside, but if the drain is plugged up, the pooling water can begin to mildew.
Old Aug 16, 1999 | 06:31 PM
Tim Pog
Guest
Posts: n/a
The vehicle is a 1996 Ford f250.
Old Aug 27, 1999 | 05:46 PM
Randy's Avatar
Randy
If everything seems to be working and draining ok,try turning the dial to "vent" a few minutes before you shut it off.I have heard this can help.
Old Aug 27, 1999 | 11:41 PM
jcd302's Avatar
jcd302
Lake Rat Jim
Oct 11, 2016 06:15 AM
berry1234
29
Oct 13, 2015 06:14 PM
queen of spades
Jun 30, 2015 10:09 AM
gaffman
Jun 15, 2007 09:07 PM
thelonerangerxlt
Appearance & Dress-Up
Jul 30, 2003 10:04 PM
