Headlight switch problum
Old Aug 24, 2022 | 10:22 AM
At least it's not a Dodge's Avatar
Headlight switch gets hot and flickers, been replaced 2 times and still does the same thing the lights were also dimmer than usual. Could anybody tell me what's wrong pls. Thanks
Old Aug 24, 2022 | 12:32 PM
Hank85713's Avatar
Hank85713
could be a bad ground in the system, need to check and clean all contacts. Or the switch connectors could be loose or dirty again check and clean.
Old Sep 3, 2022 | 03:55 PM
pawpaw's Avatar
pawpaw
Did the problem come about suddenly after some event, like adding extra lights, or higher wattage lamps, or other high current item to the light circuit, or maybe after being in a flood, or accident, or has it come about slowly over time??? Was the replacement light switch OEM, or one that says in writing its OEM quality, or was it the lowest cost part available???
Are you having problems with fuses blowing, or lamp filaments burning out???
Old Nov 25, 2022 | 12:04 PM
pawpaw's Avatar
pawpaw
BUMP:
Well, At least it's not a Dodge, been 3 months now so how is the overheating head light switch trouble shoot going, 196 curious minds would like to know!!!
pgr380
Aug 25, 2017 05:41 AM
ErrorS
1978 - 1996 Big Bronco
18
Feb 17, 2013 03:15 AM
joshofalltrades
Jan 22, 2013 07:29 PM
SmallBlockV8
Oct 13, 2009 08:29 AM
lilman320
Dec 31, 2005 01:27 PM
