Headlight Problem
Old Aug 22, 2017 | 10:03 PM
pgr380's Avatar
pgr380
Headlight Problem
88 F350 - parking lights and cab marker lights all burn as they should on first switch position. 2nd position results in no change (i.e. headlights do not come on). Dimmer switch has no effect either. I've replaced headlights and headlight switch. It seems to me that the same r/b, g/b, b wires going to the parking lights also branch off to feed the headlights, so I felt sure it was the switch. Any advice?
Thanks much
Old Aug 22, 2017 | 10:25 PM
Mudsport96's Avatar
Mudsport96
Was the socket that plugs into the switch burnt?
Old Aug 22, 2017 | 11:22 PM
pgr380's Avatar
pgr380
No, except that I can see some slight deformation of the plastic at one of the blade locations as if it had been overheated
Old Aug 23, 2017 | 03:28 PM
Freightrain's Avatar
Freightrain
That still has the old dimmer switch on the floor? Replace it. Or at least remove it and check continuity. Likely it is "stuck" between low and bright no matter how hard you stomp on it.
Quick check, unplug the switch. One wire will have 12v with the headlight switch to ON. Use a jumper to one of the other two terminals. You will get either LOW or HIGH beams. Check each. If you have lights, then replace the switch. They were VERY common to get rusty and stick "back in the day" from all the water/grime/road salt on your feet.
Old Aug 25, 2017 | 05:41 AM
pgr380's Avatar
pgr380
Hey, that did the trick! Put new dimmer switch on and lights work perfectly.
csonni
40
Jun 21, 2020 06:42 PM
1968 F100 Ranger
21
Jan 25, 2015 03:53 PM
d0n_3d
1983 - 2012 Ranger & B-Series
Dec 1, 2003 12:19 AM
g-a-w-d
Aug 27, 2003 07:14 AM
