2017 6.7 High Fuel Pressure Code issue
Old Aug 31, 2022 | 01:46 PM
colossians3:23's Avatar
colossians3:23
Originally Posted by Twofiddy67!
It was a $45 part off eBay. Not an OEM part, but same part number.
Most guys on here will give you the "motorcraft only" spiel, which I dont always agree with, however if theres one thing Ive learned from these 6.7 fuel systems, its: MOTORCRAFT ONLY!
Although, it sounds like this could all be a tuning issue. Have you checked your CP4 to make sure its not on its way out?
Old Aug 31, 2022 | 03:51 PM
Twofiddy67!'s Avatar
Twofiddy67!
I started a new thread about checking on the cp4, I’ll probably end up taking it to a mechanic to get that checked out. Not super mechanical here.
But I did order an oem motorcraft sensor that should be here soon. Hopefully that will do me better.
Old Sep 7, 2022 | 07:44 PM
Twofiddy67!
Oem sensor cleared the code.
Old Sep 7, 2022 | 08:32 PM
speakerfritz's Avatar
speakerfritz
great
congrats
Old Sep 7, 2022 | 08:40 PM
Twofiddy67!
Originally Posted by speakerfritz
great
congrats
Thank you, I’m going to take the intake off tomorrow and check the screen on the high pressure fuel pump just to be extra sure there are no metal shavings circulating.
I made a reply on the other post about the “Disaster Prevention Kit” about the specific psi numbers I got when testing the fuel rail pressure. They were off a little, but not much compared to the amount of psi.
Old Sep 7, 2022 | 11:14 PM
Evan_P's Avatar
Evan_P
Go buy the Ford part. Cheap aftermarket parts do not belong on $70k trucks with $20k engines in them.
Old Sep 8, 2022 | 12:31 AM
Twofiddy67!
Already have a brand new oem sensor installed.
Old Sep 8, 2022 | 06:47 AM
speakerfritz
review the videos on how to install the DPK kit and note the cleaning procedures of the intake valley. If you don’t clean the area around the metering valve, you run the risk of debris entering the path to your injectors.
Old Sep 8, 2022 | 12:11 PM
colossians3:23
THIS IS CRUCIAL! Ive seen this happen before. Have a syringe onhand and if you remove the metering valve and see ANY dirt/dust that fell in the fuel bowl on the top side of the CP4, GET IT OUT. Otherwise you WILL be replacing everything.
BSO2012
Modular V10 (6.8l)
20
Jul 9, 2025 08:21 PM
Rus53
Modular V10 (6.8l)
Sep 30, 2023 03:31 PM
jcal1995
6.7L Power Stroke Diesel
27
Sep 30, 2021 02:22 PM
Jkhuge
2004 - 2008 F150
Sep 28, 2017 03:12 PM
Smoke2008
6.4L Power Stroke Diesel
Jul 7, 2010 03:34 PM
