1995 F150 Throwing multiple codes
Old Aug 22, 2022 | 02:42 AM
NTrotter1997's Avatar
NTrotter1997
7th Gear
Hey everyone!
I recently bought a 95 f150 with the 351W. It has a check engine light and 4 trouble codes are being displayed.
Codes being displayed:
118- coolant temp sensor above max voltage
123- TPS above max voltage
113- Intake air charge sensor above max voltage
337- EGR position sensor above max voltage
I started with the TPS, I replaced it thinking just the sensor had gone bad. After I did that the code for that did not go away and I started checking the voltages. The power wire has 5.3v all the time which seems a little high, but the signal wire also shows 5.3v all the time. Doesn’t matter if it’s at idle or WOT. I’m thinking all of these issues may be linked since they’re the same kind of code. I was leaning towards a grounding issue.
Does anybody have any idea what would be causing these codes or how to diagnose them?
Thanks!
Old Aug 28, 2022 | 11:38 PM
Blurry94's Avatar
Blurry94
Just a reach, but does the 4 digit calibration code on the ECU match the one on the drivers side door (cab side)?
Old Aug 29, 2022 | 01:33 PM
NTrotter1997
7th Gear
Actually, it turned out to be a ground wire that had broke. Therefore not letting the sensors send a signal to the computer
btypd
Feb 10, 2014 11:43 PM
DBGrif91
Sep 9, 2013 05:21 PM
bobbyt89
Apr 13, 2010 06:53 AM
mememe
Sep 30, 2007 06:11 PM
hunter4163
Mar 15, 2004 01:32 PM
