no voltage to act or ect
Old Jan 31, 2014 | 06:28 PM
btypd's Avatar
btypd
I have a 1994 f150,351 windsor,e4od,4x4. I originally got two codes one for the tps sensor, and one saying voltage too low at act sensor. I replaced the tps sensor repaired some broken wires to the act sensor and still had no voltage to the act sensor or the ect sensor. have since replaced the ecm sill having the same problem. Has anyone ever delt with this before.
Old Feb 1, 2014 | 12:00 AM
rla2005's Avatar
rla2005
List the codes you have by number and when they were displayed, i.e. KOEO, CM or KOER. Yes, it can make a HUGE difference on the code definition and the resolution path.
Old Feb 10, 2014 | 11:43 PM
btypd's Avatar
btypd
somewhere in remodeling the house I've lost the paper that I had it all wrote down on. I do remember that it was KOEO and as far as the ACT the code was 112. The TPS code I don't remember, but after replacing the TPS, fixing the broken wires found going to the ACT and resetting the ecm, idle returned to normal with no more codes being flagged.
JF492
Jul 29, 2017 02:16 PM
Quigles4
Jan 27, 2013 12:32 PM
danjohnson67
Apr 29, 2009 09:12 AM
andy316
Dec 5, 2008 03:18 PM
tfrain
Apr 8, 2004 08:10 AM
