My first ride!
Old Aug 21, 2022 | 07:42 AM
ojh's Avatar
ojh
My first ride!
I've been working on this '95 E350 turbo diesel for almost 2 months, going thru it bumper to bumper fixin everything from electrical to mechanical, new brakes, brake lines & hoses, LED lighting, grille, engine modules, alternator, filters, tires, rust, dash wiring, sterio, clearance lights, interior panels, frame scraping & undercoating, Class V trailer hitch etc the list is extensive, but I had never driven it. I drove it for the first time yesterday and it is perfect! I was pounding the steering wheel happy while driving, its the coolest truck ever! The transmission, a remanufactored Ford unit, took a while to figure itself out and shifts solid, no hesitation, the engine is strong (a newer engine from Ford) took a 1/2hr for the temp to get above the minimum mark, 60lbs oil pressure and runs like a really noisy Rolex. It has lots of power and cruises without effort. I can't wait to get back in it.
Sometimes a lot of work is just plain worth it.
Old Aug 21, 2022 | 08:11 AM
oldbird1965's Avatar
oldbird1965
Does the cruise work? Sometimes the LED's knock out the cruise. Congrats on a fine running truck, a good feeling of accomplishment!
Old Aug 21, 2022 | 08:40 AM
ojh's Avatar
ojh
I don't know if the cruise control works, lots of things I haven't tried yet from the sterio to A/C, I am more learning and listening to the engine/transmission than anything else. Once I figure out whats 'normal' noise then I'll be able to check out everything else.
Old Aug 22, 2022 | 11:07 AM
knottyrope's Avatar
knottyrope
check fuel pressure, if low... injectors make more noise
up pipes and manifold leaks can make tick noises too
Old Aug 22, 2022 | 04:02 PM
Jrgunn5150's Avatar
Jrgunn5150
Sweet! Congratulations!
Josh88Ford
Jun 19, 2012 08:16 AM
javieljb
2004 - 2008 F150
Nov 9, 2005 10:13 AM
ckrichard
General Automotive Discussion
Mar 6, 2004 01:45 PM
MustangGT221
Jul 25, 2003 10:40 AM
