Transmission compatibility
Old Aug 19, 2022 | 03:22 PM
TrickyDick007's Avatar
TrickyDick007
4th Gear
I have a 1992 F350 2wd dually with a 351w/E4OD. The transmission is toasted.
Can I use any other transmission without having to change out the computer, or buy a different drive shaft?
Old Aug 19, 2022 | 03:56 PM
Mark Kovalsky's Avatar
Mark Kovalsky
Frmr Ford Trans Engr
No. The computer in your truck will only operate an E4OD.
Old Aug 19, 2022 | 03:57 PM
sandymane's Avatar
sandymane
The E4OD is an electronically controlled transmission by the PCM. So yes any other transmission would require a different PCM. At the expense you are going through, the cost of a reman PCM is insignificant. We have an X Ford Engineer FTE member that worked on the E4OD and he can perhaps confirm your transmission is in fact toasted. Diagnostic codes might help you or start a new thread if you need to confirm the transmission condition.
LOL just saw where Mark answered you. He is your man.
Old Aug 19, 2022 | 05:48 PM
TrickyDick007
4th Gear
The transmission fluid, when I drained it, was black and smelled burnt.
Old Aug 19, 2022 | 05:56 PM
sandymane's Avatar
sandymane
Did any symptoms prompt you to inspect the fluid?
Old Aug 19, 2022 | 06:09 PM
TrickyDick007
4th Gear
Yes. Transmission started slipping on way home from. Work. Once it was going 65 it was doing okay. Got off freeway and it didn't want to move. I floorboarded it and finally got it moving, drove it 7 blocks home floored, doing about 30 mph. Got home drained fluid, changed filter put new fluid in and it hasn't moved since
Old Aug 19, 2022 | 06:15 PM
sandymane's Avatar
sandymane
OK that is probably good information for Mark to help if he is inclined. Let's see what he says or another expert on the E4OD.
Old Aug 19, 2022 | 08:35 PM
Mark Kovalsky
If it wasn't toast before, that guaranteed that the trans is finished.
That was a waste of fluid and filter. There was exactly a zero percent chance that this trans could be saved by anything less than a full rebuild.
Old Aug 19, 2022 | 10:47 PM
wwhite's Avatar
wwhite
Yes and No.
Being a F350, your trans probably has better parts than one from a F150, example: planetary gears 4 vs 3.
1994 and earlier trans have diodes on the solenoid pack in the trans.
1995 and later the diodes are in the computer, not in the trans.
If you put a 1995 and later trans in your truck with your 1992 computer, you need to change things(solenoid pack or computer), otherwise you cook your computer.
Neufcatcat
Sep 1, 2021 11:18 AM
danlee
Aug 3, 2011 05:18 AM
fordcomfortablynum0
Jan 11, 2008 09:57 AM
ty
Jan 21, 2003 02:55 AM
