F350 E4OD Ebrake
Old Aug 2, 2011 | 12:58 PM
danlee's Avatar
danlee
F350 E4OD Ebrake
I am going to look at an E4OD from a 2wd F350. It has an Ebrake on the rear housing.
I plan to use it on my '53 F100.
Can I simply remove the Ebrake or does the tail housing have to be replaced?
Is the output shaft the same as any 2WD?
Should I just let the Ebrake stay?
Old Aug 3, 2011 | 12:42 AM
7DF250's Avatar
7DF250
I was told that the E brake assy. is the same pattern as a 4wd t-case, as in if the e-brake were removed a transfer case would bolt right up. The tech at the dealer confirmed this and said it was a 4x4 trans in a 2wd to accomadate the e-brake assembly. I dont know of any F-350 that had this setup though, could it be from an F-supeduty (F450) ??
Old Aug 3, 2011 | 05:18 AM
danlee's Avatar
danlee
This is not the trans that I am considering, but it has the same setup. This is from an E-350.
96 FORD E350 AUTOMATIC TRANSMISSION E4OD 8-460 7.5L | eBay
The trans i was going to look at is from an F350 Dually. I have decided not to bother with that trans, since it has no speedometer gear in the tailshaft. I would only buy it as a core, and change out the tailshaft.
My main question now is:
Can I leave the e-brake in place, and use my C6 slip yoke on my driveshaft. I know that my driveshaft has to be shortened.
Mims Chance
Dec 31, 2018 01:02 PM
Fordman4810
Sep 7, 2015 08:26 AM
Brown Falcon
18
Jun 19, 2011 08:21 PM
therigwelder
Offroad & 4x4
Nov 9, 2004 10:21 PM
77hiboyboy
Jun 17, 2003 01:34 PM
