Throttle cable bracket
Old Aug 18, 2022 | 11:56 PM
Joshveino's Avatar
Joshveino
1st Gear
Hey guys!
Recently bought a 1989 7.3 international. Low and behold after a few weeks of owning it my throttle cable snapped. Ordered the new part and began installing it and realized very quickly that the previous owner has Jerry rigged the wrong size cable on it. (Hence why it snapped) In doing so they removed the bracket that the cable clips to and replaced it with a piece of angle iron with notches cut out of it. Now that I have the proper cabel I'm looking for the original bracket that it clips too. I have tried searching the few things to find out a part number or something but having no luck. Unfortunately I live very far from anywhere I could dig for a scrap one.
The bracket holding it with the two bolts is what I'm after, any ideas?
Thanks!
Old Aug 19, 2022 | 07:06 AM
Olds64's Avatar
Olds64
Hopefully someone has a part number. Even if you get a part number you'd have to find a NOS piece. You might be better off fabricating your own bracket. Good luck!
Old Aug 20, 2022 | 09:02 AM
tecgod13's Avatar
tecgod13
Sounds like a junkyard find is what you need. Hopefully someone hear has a spare engine they can pull it off of to send you.
Old Aug 20, 2022 | 10:55 AM
Charmalu's Avatar
Charmalu
Check the PNP yards in your area , or go to www.row52.com
then type in F250 in the search and see what Diesels come up.
I`ll see what I have in my stash, I maybe, might have one,
Charlie
Old Aug 21, 2022 | 06:38 AM
Dieselamour's Avatar
Dieselamour
Originally Posted by Joshveino
Hey guys!
Thanks!
If this photo is the one you need, a piece of angle might be an acceptable alternative.
So far from everywhere, can you post a photo of the makeshift bracket you have so we can give you options to get a permanent (but not oem) connection?
https://www.dieselhub.com/maintenance/6.9-7.3-idi-diesel-accelerator-cable.html
Old Aug 22, 2022 | 01:23 PM
Charmalu's Avatar
Charmalu
Been searching in my pile of treasures, so far nothing.
Charlie
jackhunter
Jan 7, 2022 01:09 PM
j66b
Mar 17, 2018 04:49 PM
urbex
Sep 10, 2017 02:14 PM
fordboy300
Jan 31, 2012 12:52 PM
jcs1966
Dec 1, 2003 10:53 AM
