04 6.0
truck was running fine before ac compressor, dryer, condenser replacement.
broke the crankshaft position sensor , replaced. Did not replace plug .
code for sensor , before replacement of sensor , no code now . Still no start .
suggestions
only codes now are glowplug cylinder 2 open .
however check engine light stays on .
any suggestions will be appreciated.
note , icp is functional. Reading pressure as before injector pulse width is not .FICM 48 volts
thank you
