Sponsored by: Real Truck
2012 f250 a/c compressor
Old Feb 3, 2019 | 03:24 PM
Cody Campbell's Avatar
Cody Campbell
I have a 2012 f250. It's a king ranch. The a/c compressor doesn't turn on. Where do I start. Low freon? Or a sensor? Anything I can figure out using forscan? Thanks
Old Feb 3, 2019 | 03:39 PM
jav_eee's Avatar
jav_eee
I'd definitely start by checking your pressures. At least the low side but much better if you can check both.
Old Feb 3, 2019 | 04:37 PM
projectSHO89's Avatar
projectSHO89
If the compressor isn't running, both the high and the low sides will be identical at the static pressure.
Yes, check the static pressure. If the charge is too low and the rest of the system is working properly, the compressor will not be activated.
Old Feb 3, 2019 | 04:46 PM
Cody Campbell
I'm thinking the evap sensor is bad. It's not ohming out.
Old Feb 4, 2019 | 04:05 AM
Cody Campbell
What should the pressures be with the pump off? There about 3-4 on both sides.
Old Feb 4, 2019 | 06:15 AM
projectSHO89
System static pressure is determined by temperature. See R134a column at https://highperformancehvac.com/hvac...erature-chart/ for example.
I don't know what "3-4 on both sides" means. "3-4" WHAT? You need to use units or more details to communicate what you are observing.
Old Feb 4, 2019 | 06:18 AM
Cody Campbell
There both reading 3-4 psi on gauges. Compressor not kicking in at all.
Old Feb 4, 2019 | 08:04 AM
projectSHO89
As already noted, it's essentially empty with only a tiny residual amount of charge.
Brown Falcon
47
Jan 19, 2023 11:00 PM
tab a
1997 - 2003 F150
24
Aug 20, 2018 07:16 AM
bf5113x
21
May 24, 2016 04:00 PM
gotdiesel
Sep 27, 2007 10:25 AM
btvnetworx
Dec 6, 2003 02:49 PM
