U-joint Sizing
Old Aug 17, 2022 | 07:34 PM
motogotor's Avatar
motogotor
U-joint Sizing
I have a 1971 2wd with short tail shaft C6 with a bolt on yoke and a 2-piece drive shaft. The issue I'm having is that the transmission yoke and the drive shaft need different size u-joints but no one seems to carry a u-joint like that. The cap sizes are the same at 1" but it's 3.2" outside to outside on the drive shaft and 3.6" outside to outside on the yoke. The PO had just eyeball centered the u-joint on the yoke and tightened it down which seemed to work okay but is obviously not right. All the auto parts stores only carry a 3.2x3.2 u-joint for this truck. So I either have the wrong yoke or someone must make this asymmetrical u-joint. Anyone have any ideas?
Old Aug 17, 2022 | 08:51 PM
RichS2659's Avatar
RichS2659
Try this:
https://www.therangerstation.com/Mag.../ujoints.shtml
And this from Dana Spicer. You didn't say if it was an F-100 or 250 so I chose F-100.
https://www.danaaftermarket.com/sear...0&ymmType=AUTO
Old Aug 17, 2022 | 08:53 PM
moose4x4's Avatar
moose4x4
FTE Emeritus
If your caps are 1.063 and both side are external snap rings it should be a 353 u joint.
https://www.oreillyauto.com/detail/c...hd?q=353&pos=0
Old Aug 17, 2022 | 09:28 PM
motogotor's Avatar
motogotor
Yes, that’s the one I need. I found the same in a Moog 253 and have it on order through O’Riely.
Old Aug 17, 2022 | 09:29 PM
motogotor's Avatar
motogotor
Originally Posted by RichS2659
Try this:
This are all 3.2 in both directions which is what I have now that don’t fit the yoke right.
Old Aug 18, 2022 | 05:42 AM
Crop Duster's Avatar
Crop Duster
I answered that in your other thread and gave you a link to a FoMoCo part.
I have no idea about the speedo seal, but you have the wrong "U" joint on the driveshaft. You need one that is referred to as a big and little 1310/1330. Most parts stores will give you the wrong U joint if you aren't paying attention. Read the description you will see the dimensions are different. NOS Ford U-Joint Kit C5TZ-4635-F 1966 F100 4x4 OEM | eBay
Disregard the fitment Ford used that type of "U" joint on a gazillion different vehicles.
fulltimehiboy
Sep 22, 2007 05:30 AM
DirtyDiesel
Jul 12, 2005 09:21 AM
tangcoral2004
Jun 30, 2005 12:39 AM
Ryan50hrl
Offroad & 4x4
May 2, 2002 04:09 PM
