6R80 Problems?
Old Aug 17, 2022 | 04:52 PM
icrman's Avatar
icrman
6R80 Problems?
In a 2016 F150, just curious of what sort of problems if any, folks have had with these? I've seen something about the Lead Frame going bad and causing dangerous conditions, like down shifting to low at freeway speeds.
Old Aug 18, 2022 | 07:25 PM
jk080's Avatar
jk080
Transmission Rebuilder
I would have a 6R80 over any of the other transmissions Ford is using, its based off the ZF6HP26 transmission that you would find in cars like BMW, Range Rover.
The weak or troubled areas are:
The torque converter, it can have lockup problems, they shudder and can cycle in and out due to internal converter leaks, like a crack in the piston for the clutch.
The lead frame, this frame is the connection to all of the solenoids and has speed sensors and the manual range sensor built into it. The speed sensors are known to fail and this causes the unexpected downshifts or no shift conditions. The manual range sensor can fail and send incorrect info to the computer, this causes a no crank situation because the computer is not seeing park. The lead frame is now available again by itself, not long ago you would of had to replace the entire valve body.
The case connector is known to leak, you have to pull the pan down to get the connector out but its a easy fix.
Having no filler tube/dipstick makes checking and filling this transmission a pain to deal with. I think there are some aftermarket options for this but I have never used them.
brockstar2135
1997 - 2003 F150
Jun 18, 2022 07:49 PM
Doncon1216
Sep 24, 2013 08:49 AM
arizonasuperduty007
Arizona Chapter
May 8, 2012 04:55 PM
69cj
Nov 19, 2009 08:39 PM
