Engine Light accelerating
Old Aug 13, 2022 | 11:49 PM
Dantex1963's Avatar
Dantex1963
4th Gear
Hello!
I have a Ford F150 4.9 1995. The truck runs normal but when I accelerate the engine light comes on. What could be the reason?
I already check all vacumm lines and found one broke, fix it but didnot solve the problem.Any suggestions?
Thanks
Old Aug 14, 2022 | 02:38 AM
Prototypemech's Avatar
Prototypemech
This is usually related to your MAP sensor near your HVAC unit. It has a rubber hose running to it. Check the hose to ensure it's not cracked, broken, or disconnected.
Please take a photo of your engine compartment.
Old Aug 14, 2022 | 06:51 AM
Mudsport96's Avatar
Mudsport96
Watch this video on how to check engine light
Checking codes without a scanner
Old Aug 14, 2022 | 08:37 AM
Mark Kovalsky's Avatar
Mark Kovalsky
Frmr Ford Trans Engr
There are two ways to solve this.
First, just start checking and changing parts until it's fixed. People will give you all sorts of suggestions on what to fix or replace. Do them all, it's only money.
Second, read the codes and then you'll know why the light is coming on. Then you can fix only what's wrong instead of chasing a bunch of wrong guesses. Here is how to read the codes. www.troublecodes.net/ford
Old Aug 14, 2022 | 07:30 PM
94ZR580's Avatar
94ZR580
When the light comes on while driving , and then goes out, like when you let off the gas, that is likely the system telling you that something is happening at that moment. Read the codes, as the others have stated, and see what code was set when the light was coming on. Mine does something similar and it seems to be related to a misfire as I'm only running on seven cylinders, but I forget what codes I retrieved. There are people here who can tell you what the codes reference, so post the results of your code reading.
Old Aug 14, 2022 | 08:27 PM
Dantex1963's Avatar
Dantex1963
4th Gear
Thanks for your suggestion. I will check the hose.As soon as I have time, I will send you a picture. Thanks again
Old Aug 14, 2022 | 08:44 PM
Dantex1963's Avatar
Dantex1963
4th Gear
Thanks for your help. I will check the codes
Old Aug 14, 2022 | 08:45 PM
Dantex1963's Avatar
Dantex1963
4th Gear
I just finished watching the video. Great help.Thanks
ltmerrill
Apr 12, 2005 11:29 PM
Rude_WRX
2004 - 2008 F150
Aug 18, 2004 07:24 PM
edord
Escape & Escape Hybrid
Jun 8, 2004 11:55 AM
cruzanron
Feb 10, 2004 12:48 PM
