New/ old question
Old Aug 13, 2022 | 05:38 PM
icrman's Avatar
icrman
New/ old question
I could have asked this before ? Are any of the solenoids in the E4OD pulse modulated, or are they all on and off using 12volts for control?
What would it take to eliminate the computerized controller and just use a switch set up to manually shift the transmission?
I'm tired of the worthless PCM in these trucks.
Old Aug 18, 2022 | 07:36 PM
jk080's Avatar
jk080
Transmission Rebuilder
The EPC solenoid is, it shouldn't have more than 6 volts going to it.
They do make stand alone controllers that I believe you can adjust shift feel and timing. I personally have not used one for a E40D.
Old Aug 23, 2022 | 06:38 AM
DaveMcLain's Avatar
DaveMcLain
I'm using the Quick2 controller from Bauman to run the E4OD that I installed in my '79 F-350. It works great and the programming(using a laptop PC) is straightforward but I spent a lot of time getting it just right. It uses a TPS, speed sensor and the MLPS.
Old Sep 1, 2022 | 02:39 AM
icrman's Avatar
icrman
How much does it cost and best place to get it?
Old Sep 1, 2022 | 05:57 AM
DaveMcLain's Avatar
DaveMcLain
I bought mine using their website:
​​​​​​https://www.usshift.com/usq2.shtml
I looked on there and they have a newer version than mine and it's $455 for the controller. The wiring harness is shown as being $140-160 depending on the types of connectors that are on your transmission.
After I placed my order they called me just to double check that I had ordered all of the correct connectors.
Old Sep 1, 2022 | 01:04 PM
icrman's Avatar
icrman
Wow a chunk of change. I won't be doing that anytime soon, I'd just like to replace the truck with some old 50's or 60's thing. Just tired of over electronized junk, that can not be trusted.
Old Sep 1, 2022 | 01:35 PM
DaveMcLain's Avatar
DaveMcLain
The controller wasn't cheap but it is nicely designed, small and it mounted easily inside of the glove box. I did all of the setup with their software on a PC but it wasn't very difficult and so far after 4 years it has been reliable. One nice thing on the E4OD is that if the electronic control would conk out at least you've still got 4th gear with no lockup and high line pressure. Nothing gets hurt and it can make it home.
There might be other options on the market that are less expensive too from TCI or something but the Bauman is the only one that I've used.
Old Sep 2, 2022 | 03:10 AM
icrman's Avatar
icrman
Really so with no electronics it would still shift up to 4th? Gosh then all thats needed is a switch to turn on the lockup???
Old Sep 2, 2022 | 05:41 AM
DaveMcLain's Avatar
DaveMcLain
No it won't shift at all without electronic control. The transmission would just start out in and remain in 4th with high line pressure and no lock up. The computer does more than just tell the transmission when to shift with the E4OD. It also modulates the line pressure to control the shift quality and it does those things based on inputs for RPM, throttle position and vehicle speed. It also measures the temperature of the fluid in the pan and it can detect excessive slip.
Zhunter27
Apr 14, 2025 09:25 AM
danlee
Oct 28, 2017 09:53 PM
George D.
Jun 29, 2010 07:25 PM
gringo
Computer Chips & Tuners
Jan 20, 2007 01:05 PM
