Dually lug nuts
Old Aug 31, 2022 | 01:11 PM
  #31
Screechhawk's Avatar
Screechhawk
3rd Gear
I have a 1997 Ford F-350 Dually with stock steel wheels, (approx. 84lb ea.) : my plan is to replace with Alco
wheels ( approx 30lb ea.) with upgraded lug nuts.
Old Aug 31, 2022 | 01:16 PM
  #32
Screechhawk
3rd Gear
Again with 1997 OBS Ford F-350 dually. I drive many dirt roads around the S.W.I can not find a company that sells mud flaps
for OBS Fords? Dirt roads play heck with truck & trailer. Anybody know of a company that sells front, rear mud flaps? Thanks.
Old Aug 31, 2022 | 01:25 PM
  #33
redford's Avatar
redford
FTE Leadership Emeritus
Duraflaps should have you covered.
https://duraflap.com/truck-model/ford/
Old Aug 31, 2022 | 01:57 PM
  #34
DPelletier's Avatar
DPelletier
Originally Posted by Keokie
Which lug nuts did you order?
The Ebay ad said OEM take-offs - not sure which Ford trucks came with closed nuts....
Dave
Old Aug 31, 2022 | 02:34 PM
  #35
dpbergen's Avatar
dpbergen
So if you have a 2022 6.7L crew cab, 8' bed, 4x4 dually, Platinum - don't buy this slide hammer to remove your hubcaps - it doesn't work.
The slide hammer is OTC5758. Some day I'll get my grinder and welder out and modify it so it will. The angled tip won't fit the slot on the hubcaps (front or rear). I do like the idea however.....
One Sock
Nov 22, 2022 11:21 PM
Kep4
6.7L Power Stroke Diesel
Oct 30, 2011 06:28 PM
gcwells2
Jan 14, 2011 11:55 AM
ckal704
Jun 8, 2009 08:31 PM
