Dually lug nuts
Old Aug 16, 2022 | 08:49 AM
westracing01's Avatar
westracing01
https://www.coyoteaccessories.com/lugs/lug-nuts/86kx48
Would those fit the bill?
As a side note, even though they don't say it, I assume these would work on the F450 too?
I made a tool to remove those caps, but the wife likes the wheel without the caps too so I may go the paint the hub with nice lugs route eventually.
EDIT: Actually, I really like that Raney's kit. Expensive, but I like it.
Old Aug 16, 2022 | 11:42 AM
Keokie's Avatar
Keokie
Originally Posted by speakerfritz
I remove my caps using one of those orange wratchet straps and a piece of wood. hook the cap using the wratchet strap hook, tie the other end of the wratchet strap to a wooden stick....put the stick on the ground...use your foot to keep the stick steady....yank on the top of the stick as if the stick was a lever....the cap will come right off.
I haven't found the caps too difficult to remove. I just think they look cheap and bulky.
Old Aug 16, 2022 | 01:45 PM
cpobst's Avatar
cpobst
Indexable pry bar works great to remove them.
Old Aug 16, 2022 | 06:01 PM
MJMETHOW's Avatar
MJMETHOW
Can you tell me the size and brand? Thanks
Old Aug 16, 2022 | 06:08 PM
cpobst's Avatar
cpobst
I carry them in my truck with the microfiber to put between the pry bar and wheel. They pop right off.
Old Aug 17, 2022 | 07:39 PM
bobv60's Avatar
bobv60
I made a tool to take them off, very simple and EASY
File Type: mp4
Old Aug 24, 2022 | 12:50 AM
Flywheel17's Avatar
Flywheel17
Water Junky - that looks great - thanks for sharing - can you post a pic of the whole side of the truck?
Thanks -
Old Aug 24, 2022 | 09:35 AM
water_junky's Avatar
water_junky
Thanks -
Old Aug 24, 2022 | 09:50 AM
Flywheel17's Avatar
Flywheel17
Looks great - thanks - helpful as I have the exact same truck.
Old Aug 24, 2022 | 12:05 PM
cfpinz's Avatar
cfpinz
Originally Posted by Miles Mac
Just painted the hubs chassis black w/ stock lug nuts, no one even notices - Removed the center caps ONCE... swore I'd never do it again.
Same here. They're stuck on a shelf somewhere in case I decide to sell the truck down the road.
Old Aug 24, 2022 | 05:02 PM
HotelFoMoCo's Avatar
HotelFoMoCo
Originally Posted by DPelletier
Hi all; I did a search and found little other than the fact that the plastic wheel caps seem very difficult to remove. I plan on removing them permanently and would like to replace the factory front lug nuts with high quality chrome or stainless nuts. On the back, I will either do the same and just paint the axle or find a SS center cover to cover the axle hub but not the nuts. Any suggestions?
Thanks,
Dave
Great video on You Tube by Arod at PowerStroke Tech Talk. He shows how to use a piece of 2x2 to pop them right off. I had some 2x2’s around here. Cut two pieces to about 24”. Keep ‘em in the truck. Works very well. I don’t receive anything for recommending him. One of the sharpest techs around.
Thanks Arod.
Old Aug 24, 2022 | 05:07 PM
DPelletier's Avatar
DPelletier
Thanks, getting them off is one issue, but ultimately I think they look cheesy and probably make it more difficult to get an air chuck in there. I've ordered some lug nuts and I think I'm just going to paint the rear hub black.
Dave
Old Aug 24, 2022 | 05:54 PM
  #28
Keokie's Avatar
Keokie
Dave
Which lug nuts did you order?
Old Aug 24, 2022 | 06:05 PM
  #29
MJMETHOW's Avatar
MJMETHOW
Thumbs up
I also have the same truck.
Old Aug 24, 2022 | 06:18 PM
  #30
david kallin's Avatar
david kallin
4wd Low
1997 OBS Ford F-350 CC LB Dually/ 7.5 Eng. I have notice this isn't a thread that pertains to (OBS) Old Body Style,1990-1997 Ford F-250, F-350
on this Forum, at least not listed for what I have seen? On a second note I've been trying to find if anyone on this forum has a
simulator vehicle as listed above with stock rims (16"x6.5") and have changed them over to 17", 18" or 19" rims? I would think if
you kept the dually set-up they would rub without spacers?
