No o2 heater voltage
Old Aug 11, 2022 | 07:50 AM
Bak20041's Avatar
Bak20041
Hi, I’m having a problem on my 2003 Ford F-250 v10 with no o2 heater voltage on the passenger side, driver side o2 is functioning perfectly fine just no voltage on passenger side heater
Old Aug 11, 2022 | 01:30 PM
Franklin2's Avatar
Franklin2
Check fuse #23 in the underdash fuse box.
Old Aug 11, 2022 | 01:33 PM
Bak20041's Avatar
Bak20041
thanks for the suggestion, will do when I get home and will report back, I believe that it’s the ground from the pcm I believe that I’m missing, I have the 12v positive just not the ground, trying to help you understand my situation, is there a relay to the o2 heaters on the ground side?
Old Aug 11, 2022 | 03:40 PM
Bak20041's Avatar
Bak20041
fuse 23 is good, all fuses under steering wheel are good, not sure about relays
Old Aug 12, 2022 | 02:00 PM
Franklin2's Avatar
Franklin2
No relays to the O2 sensor heater circuit. You can see in the 2 diagrams below, the PCM provides the ground when it wants the heaters active.
Old Aug 12, 2022 | 02:04 PM
Bak20041's Avatar
Bak20041
interesting, could I have a bad pcm?
Old Aug 12, 2022 | 04:08 PM
Franklin2's Avatar
Franklin2
If the grounding wire is good all the way back to the PCM, yes you could. Make sure you also check the 12v at the sensor plug in with a testlight, not a digital voltmeter. You need to load the circuit down when testing, the digital meter does not present enough load if there were a bad connection in the 12v wiring.
Old Aug 12, 2022 | 04:57 PM
Bak20041's Avatar
Bak20041
how could I check if the ground is good to the pcm?
Old Aug 12, 2022 | 06:55 PM
Franklin2's Avatar
Franklin2
You would have to unplug the large PCM connector, find the correct wire, and then put your meter on ohms, backprobe the connector with one lead, and probe the ground at the O2 connector with the other lead. Of course you may need a scrap piece of wire to extend one of the meter leads to reach. You should get a reading very close to the same as you get by just touching the meter leads together, very close to zero ohms.
Old Aug 12, 2022 | 07:08 PM
Bak20041's Avatar
Bak20041
thanks, will have to do that when I get time, you wouldn’t happen to have a clue as to which wire it is going to the pcm would you?
Old Aug 13, 2022 | 06:17 PM
Franklin2's Avatar
Franklin2
The second diagram in the post #5 above shows it as pin 93 and 94.
Bak20041
Modular V10 (6.8l)
Aug 11, 2022 09:40 AM
Travistjm1
Jun 23, 2013 06:35 PM
53choptop
Nov 11, 2003 08:52 AM
krewat
Modular V10 (6.8l)
Mar 13, 2003 03:56 PM
tcunard
Dec 4, 2002 11:59 AM
