Leaf spring spacers
Old Aug 5, 2022 | 11:05 AM
klassic's Avatar
klassic
Leaf spring spacers
The leaf springs in my 17 350 were creaking like crazy.
I hunted trying to find replacement spacers.
Ended up at the dealer and they were $26 (CAD) for 1!!
I bought the Ford ones because Amazon said the ones I found don’t fit my truck.
Bought the Amazon ones too just to see, and yes they do fit and they are only $9 for 4 of them.
So if you’re looking, don’t go to Ford.
These Doorman ones fit perfectly.
Dorman 924-070 Leaf Spring Spacer
here’s a pic of the three I took out. I’m just going to replace them all.
Old Aug 5, 2022 | 01:00 PM
Superdave71's Avatar
Superdave71
I had the same issue on my 16. I replaced them with the Dorman replacements, which were a 2 part, a base and a rubber spacer. They failed within a year, but because the locating tab sheared. I suspected it sheared because the rubber spacer didn’t support or let it slide, like the original. I installed a second set without the rubber and it was fine, lasting longer than the factory pieces.
Old Aug 5, 2022 | 01:03 PM
OBS460's Avatar
OBS460
Motorcraft > Dorman always. People trying to save money with Dorman parts end up spending more sometimes because you have to replace it sooner.
Old Aug 5, 2022 | 01:06 PM
Superdave71
I agree wholeheartedly, when I inquired my dealer told me to order the dormans because he couldn’t get them. This was 2018 though.
Old Aug 5, 2022 | 02:33 PM
klassic's Avatar
klassic
you may be right…but they sure feel and look the same as the new Ford part.
Like the other comment, maybe it will shear off the pin.
but at $20 for 8 vs $240, I’ll risk it.
Old Aug 5, 2022 | 02:52 PM
OBS460's Avatar
OBS460
I do agree it is cheaper to buy the Dorman part multiple times over and some parts it isnt a big deal because it isnt hard to replace. Things like unit bearings are a pain to replace until you replace the Dorman part 3 times and you get it down to a science. If the spacers are easy to swap out buy 2 full sets for $40 and be $200 ahead still. If they have a warranty make sure ro check them before its expired because you may even be able to get them replaced for free. FoMoCo does think very highly of their parts.
Old Aug 5, 2022 | 09:22 PM
HRTKD's Avatar
HRTKD
Dorman sucks. They're the last brand I'll use if that's all that is available.
Myers B
Feb 24, 2020 06:37 PM
cyclone-429
Sep 11, 2015 07:43 AM
Dereck
Jun 29, 2013 03:12 PM
ChaseTruck754
Jun 25, 2012 06:12 PM
teardropty
Feb 14, 2011 05:30 PM
