Mississippi Chapter Join Chapter , Leader: Scndsin
August For Us Monthly BS Thread
Old Aug 6, 2022 | 04:41 PM
Scndsin's Avatar
Scndsin
Thanx but Digital pics LIE.
Old Aug 6, 2022 | 06:27 PM
56panelford's Avatar
56panelford
There was a time when I had a beautiful lawn then the government banned herbicides for non-commercial use..and the crap they sell now is expensive and doesn't work all that well ..
Old Aug 6, 2022 | 06:51 PM
Scndsin's Avatar
Scndsin
Easiest way to grow a lawn around here is lay down some gravel & park a car on it.
I'm fighting a couple invasive weeds along with the dozen or so usual suspects.
Don't know what I'd do if I had to fight poison ivy, oak, Virginia creeper, morning glory, etc without round-up even though It'll probably get me eventually.
Old Aug 6, 2022 | 07:21 PM
56panelford
All you can buy around here is watered down Killex and I already pay enough for water...lol Every weed known to man seems to do well here..
Old Aug 10, 2022 | 10:46 PM
Scndsin's Avatar
Scndsin
So, it started with finding out why headlight flopped around.
Escalated to cleaning crud outa' the nose.
Old Aug 12, 2022 | 11:24 PM
ranger140892's Avatar
ranger140892
Grumpy goat
Geez, the crud was keeping the headlight from flopping around!
Old Aug 15, 2022 | 10:05 AM
Scndsin's Avatar
Scndsin
Welcome to another sunny, cloudy, rainy, steamy, sweaty week in the deep south.
Be well, be safe.
May your Ford do what it should & do-it well.
Old Aug 15, 2022 | 10:29 AM
56panelford
Hello David, I got that spare motor home the other day..
Got the wiring and ECM
Old Aug 15, 2022 | 01:39 PM
Scndsin's Avatar
Scndsin
Wow. Nice haul. Cut your efi teeth on the hot rod dually & the next will be like falling off a log.
Old Aug 15, 2022 | 01:50 PM
56panelford
How easy are these to get running in a project like I have going, wiring is going to be a nightmare for me..
Old Aug 15, 2022 | 02:31 PM
Scndsin's Avatar
Scndsin
With the right diagrams, it's no big deal if you have a passing knowledge of control systems.
I know a couple of fat fender guys have already done similar with 5.0s, T-5s & AODEs.
.Speed density batch firing 4 injectors per bank a cycle run by a MAP sensor is pretty simple.
Question is, do you wanna' keep the fuse block & headlight/signal lamps.
Or you can go aftermarket for both engine & trans.
Old Aug 15, 2022 | 02:48 PM
56panelford
Transmission on the project I'm doing is a manual ZF47 , just need the engine to run so not sure what all is needed from the Ford wiring . Road maps are easier for me to follow than wiring diagrams..
Old Aug 15, 2022 | 06:30 PM
  #28
f1504x4driver's Avatar
f1504x4driver
Proud Pirate
While the wiring seems like a mountain to climb it is rather simple compared to newer trucks. As David said, with the proper diagram and help here its nothing you cant tackle. I am lousy at it but David has made it rather simple, even for me.
Old Aug 15, 2022 | 06:52 PM
  #29
56panelford
I'm not ready yet to start the wiring but definitely will be needing to pick your brains ,rest of the wiring I can handle using an Ezwire kit..
Old Aug 15, 2022 | 07:04 PM
  #30
Scndsin's Avatar
Scndsin
I forgot your donor was manual, right? And you still have the whole truck & computer?
If so, we should handle it. You could ship to me & I'll hack it over the winter if all else fails. Should be relatively simple.
