messed up water pump?
Old Aug 2, 2022 | 08:19 PM
dremtofford's Avatar
dremtofford
i went to remove my dist. to start rebuilding the top end of my 88 302 and found someone put nuts and bolts in the top of the water pump just long enough so i couldn't get to the dist hold down. and the bolts in the water pump had lock tight on them. a little torch to heat them up and the lock tight finally broke loose. what a pain.
Old Aug 3, 2022 | 08:21 AM
jas88's Avatar
jas88
Prolly because they stripped the threads out of the aluminum timing cover.
Old Aug 3, 2022 | 10:54 PM
dremtofford
messed up water pump.
that is what i figured. so i have two choises either take the timing cover off, i need to check the timing chain anyway, or ignore that and put helicoils in, or both.
Old Aug 4, 2022 | 08:55 AM
dremtofford
what size are supposed to be in there?
mattnj
Oct 6, 2016 08:46 PM
kkrapp
May 1, 2013 09:07 AM
Tazz452
1978 - 1996 Big Bronco
Nov 15, 2004 06:51 PM
jommer
Feb 27, 2004 04:02 PM
tadslc
Oct 27, 2003 02:27 PM
