Help! I'm in desparate need of a clutch release equalizer ball and bracket. '64 6 cyl., three on the tree. Tried the obvious- (Mac's, etc.) without luck. Anybody out there with any suggestions?
You on't mention if it's 2wd or 4x4, so here's the part numbers for both sides ( engine & frame) : 2wd is C3TZ 7507-C for frame side, C1TT7A572-E (223 CID)engine side. 4wd is C1TT 7507-A, frame side and C1TT 7A572-J, engine side. You can try many of the NOS suppliers out there or try www.partsvoice.com and use the parts finder there. Use your zip code as a password. it will list anyone on thier list who shows it in stock. It lists phone numbers to call also. I use it all the time.
If your truck is 4wd, I've located both pieces( frame side and engine side. E-mail me at clussy38@aol.com and I can email back with location and phone numbers to call.
