92 Ford E350 Jasper E40D Neutral Safety Switch
Old Jul 31, 2022 | 09:38 AM
wwwheaty's Avatar
wwwheaty
Spent the big bucks $4400 (yikes) on a Jasper reman transmission installed. Out of the shop it worked fine. Had intermittent no-start needing to jiggle or move shifter out of park and back into park to start. Dammit. Back to shop. They said they verified the complaint and adjusted the switch. Now down the road same thing happens. Dammit.
Is this my problem to pay for?
Old Jul 31, 2022 | 03:24 PM
tabijan's Avatar
tabijan
My guess is they’ll blame slop in the shift linkage and they’ll probably be right.
Sixto
07 E350 5.4 183K miles
Old Jul 31, 2022 | 04:07 PM
wwwheaty's Avatar
wwwheaty
Maybe but my old transmission didn’t have this problem. Not sure if it has a new NSS or not.
Old Jul 31, 2022 | 05:01 PM
tabijan's Avatar
tabijan
Is it difficult to adjust the NSS? On other cars I put the transmission in reverse and have someone call out lights on or off as I rotate the NSS. Tighten the NSS in the middle of the lights on range. Hopefully that’s all it takes and they’ll adjust it again at no charge..
Sixto
Old Aug 1, 2022 | 11:28 AM
manicmechanic007's Avatar
manicmechanic007
There is a procedure to adjust your MLP sensor or TR sensor. Basically you adjust it to start only in neutral and park. The Ford ones are pricy so the rebuild shop might not have replaced yours.
I think you should just replace it yourself with a cheap Autozone one. They come with a pin in them that helps with alignment.
Manual lever position sensor and Transmission range sensor, they both control the backup lamps and the neutral start functions, as well as telling the processor what the lever position is.
Good luck
Old Aug 1, 2022 | 12:01 PM
wwwheaty's Avatar
wwwheaty
MLP ?
TR sensor?
the reman transmission came with a NSS.
Jasper warranty conversation says bring it another shop. Although the reimbursement rate is $75 - $85 per hour.
Old Aug 1, 2022 | 12:15 PM
Mark Kovalsky's Avatar
Mark Kovalsky
Frmr Ford Trans Engr
The name NSS isn't used anymore. It changed to MLPS (Manual Lever Position Sensor) and then changed to TRS (Transmission Range Sensor.) They all describe essentially the same part. The difference is that the MLPS and TRS also have a part that sends data to the PCM to show where the trans shifter is at. The NSS doesn't do that.
A 1992 C6 would have a NSS, a 1992 E4OD would have a MLPS (also called TRS.)
Old Aug 13, 2022 | 03:59 PM
wwwheaty's Avatar
wwwheaty
The Jasper provided switch was faulty. A replacement switch was installed and all is well. Thanks for your posts.
Old Aug 13, 2022 | 08:19 PM
manicmechanic007
I swear they soak the old ones in cleaner and resell them
Old Nov 26, 2022 | 09:08 AM
coolfeet's Avatar
coolfeet
Is it possible that a faulty TRS will crank and not start? My 2003 E350 occasionally cranks and does not start. When I move the shift lever through the gears and back, I can start it in neutral or park.
Old Nov 26, 2022 | 09:31 AM
manicmechanic007
The TR sensor should not have anything to do with a no start issue
That said
I had a newer Probe 96 or 7 was a no start
Checked everything several times
Found a cruise control fuse that took out the coil pack (not in the book)
Anything is possible, I'd replace the TR sensor with a new Motorcraft one and retest
Old Nov 26, 2022 | 09:38 AM
coolfeet's Avatar
coolfeet
Thanks for the quick response.
squinne
Jan 16, 2016 07:36 AM
eddie50
2004 - 2008 F150
Oct 15, 2012 04:55 PM
shane74
Jan 11, 2004 06:27 PM
GeneStoner
Oct 17, 2002 05:55 PM
75fef100xlt
Jul 26, 2001 08:05 PM
