Sponsored by: Real Truck
P1247 and boost pressure.
Old Jul 29, 2022 | 12:40 PM
Jvankuiken's Avatar
Jvankuiken
4wd Low
I've been working through the codes on my stock (as far as I know) e99 f250 with 7.3. I got all my codes resolved and the truck is running good but then I got code p1247 low boost pressure. I bought a boost guage and at normal driving (60mph no load) I sir at about 5psi. When I floor it I can make up to 15-17psi. This seems normal for a stock truck. I replaced up pipes, manifolds and re-sealed/new wheel for the turbo. All connections are tight. So is my MAP sensor bad? I cant find any leaks so that's all that's left right? I'm new to diesels so thank you for all the help.
Jake
Old Aug 3, 2022 | 01:26 AM
Evan_P's Avatar
Evan_P
Inspect the MAP sensor feed tube from the plenum to the sensor. The hoses get very hard over the years and can crack or split.
Oilfield Trash
17
Mar 2, 2016 12:41 PM
baredog26
Dec 9, 2010 11:30 AM
wmiller
17
Aug 10, 2007 04:16 PM
Rodeohauler300
Apr 2, 2007 02:24 PM
stephen.south
Mar 1, 2007 06:25 PM
