FORD Ordering Info
He talks mostly about the Maverick and the roll over of orders. I know that roll-overs is not normally done but it is being done this year. And for those that have SD orders, it gives a hint of what MIGHT happen to your orders if your confirmed 2022 SD order is not built.
Then he goes into the different models and there is some SD info. There is a little bit of info of the Aug production numbers for the SD. At 54:00 he talks about SD constraints.
This video is long and not all info will be interesting to you but is in depth. He also has a library of videos if any of those are interesting to you. I hope this helps people here in the SD forum.
