Driver’s Side Block Drain Identification
Old Sep 11, 2023 | 08:28 AM
brian42's Avatar
brian42
Veteran: Navy
How many miles do you have on the truck?
I replaced my fan clutch around 180K miles and 10K miles later my water pump was on the way out...and I was taking the fan off again to do that work.
As for the block plugs, definitely spray them for a few days to loosen them up. They are not the hardest material so there's a risk of rounding out the square hole to remove them. Make sure you have a good 1/4" ratchet square that takes up the whole hole. The more play you have with the tool the easier it is to round out the square. I have that t-shirt.
Old Sep 11, 2023 | 01:04 PM
marksman76's Avatar
marksman76
243736 miles.
Water pump was done probably 100k miles ago by my Ford dealer, with a coolant flush.
I am doing my own first cooling flush, and replacing bad fan.
Believe me, I thought about doing water pump also, but have not finalized that decision yet.
Old Sep 11, 2023 | 01:32 PM
Kwikkordead's Avatar
Kwikkordead
That block plug is 3/8" drive square hole, not 1/4" If you strip it out, then the best recourse is something like this.
Picture taken from this tool kit.
https://www.harborfreight.com/multi-...gg_q=extractor
Old Sep 11, 2023 | 01:43 PM
cleatus12r's Avatar
cleatus12r
Butt-Head
The coolant plugs are 1/4" square.
Old Sep 11, 2023 | 03:49 PM
Whitey Ford's Avatar
Whitey Ford
FTE-Spread The Knowledge
Yep, 1/4” square socket end!
Old Sep 11, 2023 | 05:53 PM
Kwikkordead
Sorry guys. I was crossed over in my head with the ZF6 drain and fill plugs.
Old Sep 12, 2023 | 11:41 AM
marksman76's Avatar
marksman76
Does anybody know the part numbers for these little block drain plugs.
I am thinking obviously the 1/4" drive is going to round it a little bit, so maybe the best practice would be to replace them with new ones EVERY TIME
OK I just found this on the forum using a google search.
But if anyone has a different actual part number that would be nice.
I believe that plug is 1/4-18. You can buy them at a good parts store, and you might get lucky and find one at Lowes or Home Depot in their specialty bins.
I think the part number is 444619... "plug, 1/4-18" - That is what the diagram shows. There is another plug near the oil cooler labeled in the book as "plug, oil cooler drain, 3/8 NPTF" with part # 445684
Old Sep 13, 2023 | 01:09 PM
Kwikkordead
The plugs on my block are male fittings. Needs a square drive socket to engage.
Old Sep 28, 2023 | 03:58 PM
marksman76's Avatar
marksman76
I am curious,
I thought I read years ago that there was multiple block drain plugs on each side.
I was just under vehicle near the oil filter and I saw two more plugs that had an extruded square head about 5/16" square.
Is there multiple plugs that are necessary to remove for the COMPLETE block drain?
Thank you
Old Sep 28, 2023 | 04:52 PM
cleatus12r's Avatar
cleatus12r
Butt-Head
No, on a level surface, the rear block drain holes are at the lowest point of the cooling system due to the tilt of the engine.
The other plugs you speak of with the 5/16" internal square are there to drain oil from accessories (like air compressors from medium-duty truck applications) mounted to the engine straight into the crankcase. You won't drain anything from those....but you will make a mess if they are left out with a running engine as the spinning crankshaft flings oil out.
Old Sep 28, 2023 | 05:19 PM
uglypitbull's Avatar
uglypitbull
Mine started to strip a little once...I bought
a set of these a set of these
and it worked perfectly. I also use them on my differentials and transfer case.
Old Sep 28, 2023 | 07:20 PM
jstihl's Avatar
jstihl
Originally Posted by uglypitbull
Mine started to strip a little once...I bought a set of these and it worked perfectly. I also use them on my differentials and transfer case.
These definitely do come in handy, have used them on other projects as well. One of those once in a blue moon tools but great to have
Old Sep 28, 2023 | 10:21 PM
  #28
marksman76's Avatar
marksman76
So I called my local Motorcraft dealer today and told my parts guy I needed a water pump PW 455 , now apparently superseded by a PW 663,
and a lower radiator hose KM 4542.
So I unboxed the new water pump, and checked the country of origin CHINA.
Any way, inside was a water pump gasket with semi oval nibs on both sides.
So I am trying to fit it in there correctly, and I keep ending up with extra?
Any thoughts, tips, advice would be greatly appreciated.
Old Sep 29, 2023 | 01:28 AM
  #29
marksman76's Avatar
marksman76
I saw at least two plugs that were 1/4" external square nuts, ..... ..... not 1/4" internal square drive.
Old Sep 29, 2023 | 02:47 AM
  #30
cleatus12r's Avatar
cleatus12r
Butt-Head
Oil pressure in those.
motown
Modular V8 (4.6L, 5.4L)
Sep 8, 2021 04:01 AM
Godzillamax
Nov 20, 2017 01:13 PM
ealbertson
Apr 2, 2006 07:30 PM
peterjeff
Oct 2, 2004 09:33 PM
Skeetshooter
May 22, 2004 09:24 PM
