Wheel cleaner
Old Jul 28, 2022 | 07:42 AM
MARCSPSD's Avatar
MARCSPSD
Power Stop Z36 as well.
Almost no brake dust.
Stops as well or better than OEM. Smooth as butter!
No rust on rotors at all. I back out of a steep driveway each morning. With the Power Stop Z36 carbon ceramic pads and slotted disk setup, never a problem with surface rust. (1st brake application of the day would normally be a problem with surface rust on the rotor, at least in reverse at slow speed. )
I have had an ongoing problem with rotor build up, commonly known as warped rotors. Not anymore.
So far one of the best upgrades I have done. And not expensive if you shop around.
This was for my PSD EX 4x4. Not a late model Superduty.
Old Jul 28, 2022 | 09:19 AM
HRTKD's Avatar
HRTKD
I prefer to use soap and a brush or rag. I used spray on wheel cleaner on my prior truck. It caused problems with the brake pads. After that, I never spray anything in the vicinity of my brakes.
For my WeatherTech mats I hit them with a power washer and then use simple dishwashing soap and a brush. The power washer gets most of the stuff off, but doesn't leave the mats looking clean.
Old Jul 28, 2022 | 09:37 AM
cficare's Avatar
cficare
Simple Green causes (bare, uncoated) aluminum to oxidize. I recall a story of some military helicopter servicemen being restricted from using it aboard their aircraft. I used to use it to clean what were polished aluminum rims on a GT40 kit car, but turns out I liked the oxidized finish better.
MCDavis
2004 - 2008 F150
Sep 13, 2010 04:44 PM
bddo
1997 - 2003 F150
Nov 17, 2005 10:13 PM
acetrebo
22
Jun 20, 2004 10:22 PM
